Got a code on upload....
swamp_life hemi 05
Tallahassee Fl.
2005 laramie
On went to upload the 3685 I got from JJ and it saves stock file, then I tells me and error on upload??? Code t-42, then tried again and it dis the same thing... But code t-48. Plz help. Thanks in advanced
Droid Incredible 2 on the move!!!
BlackedOutHemi
DFW, Texas
2012 & 2012
5.7L HEMI & 6.7L Cummins
Does it need to be updated?
swamp_life hemi 05
swamp_life hemi 05
Tallahassee Fl.
2005 laramie
I'm gonna try that this evening. I just did some researching on the superchip site and a similar topic came up, ill try updating.
swamp_life hemi 05
swamp_life hemi 05
Tallahassee Fl.
2005 laramie
Ok tried to update but I keep getting a "read tuner error" on my computer??
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
what the frack?
Your best bet will be to contact SC customer service, they can get you squared away!
tmerritt530
287 ci
Ive gotten general error twice on mine. Dont have a clue what that means so i just tried again and it worked. Hope you can get yours goin'
swamp_life hemi 05
swamp_life hemi 05
Tallahassee Fl.
2005 laramie
Ok it's finally updating on the computer!!! Hopefully it'll tuner to the truck ;)
swamp_life hemi 05
swamp_life hemi 05
Tallahassee Fl.
2005 laramie
Well still error, t42code. With all the research IM finding on the superchip website it's looking like imma have to go get my pcm reflashed! Oh well guess it's off to the stealership.......
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Before you go to the dealership hook a battery charger up to your truck while your trying to load the tune. Have everything off in the truck also, the trucks are sensitive to voltage changes and might be causing the tune error.
swamp_life hemi 05
swamp_life hemi 05
Tallahassee Fl.
2005 laramie
Ok I'll try that. Is it usual for the tuner to make the dash lights and headlights come on and off???
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
yeah, it does that. Sometimes it would whisper sweet nothings in my ear too. Pretty slick unit!
swamp_life hemi 05
swamp_life hemi 05
Tallahassee Fl.
2005 laramie
Yea I hope as long as it does whisper the sweet nothings it'll finally upload!!! Lol
swamp_life hemi 05
swamp_life hemi 05
Tallahassee Fl.
2005 laramie
And also is it normal for it to get to 81% on the saving file 1 screen and stop?? Then go through regular saving stock file 2??
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
errrrr.................never saw that on my truck, but I only had 1 file. (different in the newer trucks)
swamp_life hemi 05
swamp_life hemi 05
Tallahassee Fl.
2005 laramie
Imma give it a rest for tonight. I'll be able to get ahold of superchip tomorrow. Then if all else fails I'll go get the pcm reflashed..... Does anyone know how much that will run me???
swamp_life hemi 05
swamp_life hemi 05
Tallahassee Fl.
2005 laramie
Well the dealer is wanting to charge me $300 to reflashed the pcm,tcm,and skin key...... Is there any other way???
Oefootball_70
OLATHE
You need to call Superchips, they can help you out better. It sounds like you might have locked up the tuner by messing something up in the download. But I haven't had one in a long time so I can't verify that.
SilsHemi
Contact Superchips tech support before you do anything. They may be able to help you. 1.888.227.2447
noraa73
