PICS 06-08 regular mirror dis-assembly
Milton, WV
5.7L
BlackedOutHemi was a big help to me through this though I think we have different mirrors the concept was similar
once you take the mirrors off your truck lay them down on a bench floor table whatever your heart desires push in on the upper inside corner.
reach in and pull up on the lower outside corner "popping" the mirror off
once off disconnect the wires if you have heated mirrors shown in the circle
then you are left with the mirror shell and motor look to the bottom there are two tabs an upper and a lower on the outside edge of the mirror housing and one upper tap on the inside upper part of the shell unclip the tab pushing down and the back will fall off
hope this helps people and is clear and easy to understand
Budakane
Northern VA
345ci Hemi
How do you take the mirrors off w/o breaking them?
LB3711
Trumbull, CT
3.6L V6
Patience. Lol
Sent from my tapatalk equipped AT&T iPhone 4.
reddot
Wolf Point, MT
5.9 cummins
ill be doing this this weekend maybe depending on weather to add/test LED marker lights to my 06 tow mirrors.
great write up.
