Diagnostic Trouble Codes
Status
Not open for further replies.
MADDOG
Out Exploring Arizona
Here are some translations of common Diagnostic Trouble Codes (DTCs).
Ho2S = heated oxyen sensor, TP = throttle position, MAF = mass airflow, MAP = manifold absolute pressure, TC=turbocharger.
Some codes might not apply to a Ram as much as they do to a LX car (300, Charger, etc...) and additions or changes to this list will be appreciated.
* P0030: Sensor heater relay problem
* P0030 HO2S Heater Control Circuit Bank 1 Sensor 1
* P0031 HO2S Heater Circuit Low Voltage Bank 1 Sensor 1
* P0032 HO2S Heater Circuit High Voltage Bank 1 Sensor 1
* P0036 Sensor heater relay problem
* P0036 HO2S Heater Control Circuit Bank 1 Sensor 2
* P0037 HO2S Heater Circuit Low Voltage Bank 1 Sensor 2
* P0038 HO2S Heater Circuit High Voltage Bank 1 Sensor 2
* P0050 HO2S Heater Circuit Bank 2 Sensor 1
* P0051 HO2S Heater Circuit Low Voltage Bank 2 Sensor 1
* P0052 HO2S Heater Circuit High Voltage Bank 2 Sensor 1
* P0056 HO2S Heater Circuit Bank 2 Sensor 2
* P0057 HO2S Heater Circuit Low Voltage Bank 2 Sensor 2
* P0058 HO2S Heater Circuit High Voltage Bank 2 Sensor 2
* P0100 MAF Sensor Ckt. Insufficient Activity
* P0101 Mass Air Flow (MAF) Sensor Performance
* P0102 Mass Air Flow (MAF) Sensor Circuit Low Frequency
* P0103 Mass Air Flow (MAF) Sensor Circuit High Frequency
* P0104 Mass Air Flow Circuit Intermittent
* P0105 MAP Sensor Circuit Insufficient Activity
* P0106: MAP sensor voltage out of range detected at startup (probably bad sensor, possibly wiring problem)
* P0107 Manifold Absolute Pressure (MAP) Sensor Circuit Low Voltage
* P0108 Manifold Absolute Pressure (MAP) Sensor Circuit High Voltage
* P0109 Manifold Absolute Pressure Circuit Intermittent
* P0110 Intake Air Temperature (IAT) Sensor Circuit
* P0111 Intake Air Temperature (IAT) Sensor Performance
* P0112 Intake Air Temperature (IAT) Sensor Circuit Low Voltage
* P0113 Intake Air Temperature (IAT) Sensor Circuit High Voltage
* P0114 Intake Air Temperature Circuit Intermittent
* P0115 Engine Coolant Temperature (ECT) Sensor Circuit
* P0116 Engine Coolant Temperature (ECT) Sensor Performance
* P0117 Engine Coolant Temperature (ECT) Sensor Circuit Low Voltage
* P0118 Engine Coolant Temperature (ECT) Sensor Circuit High Voltage
* P0119 Engine Coolant Temperature Circuit Intermittent
* P0120 Throttle Position System Performance
* P0121 Throttle Position Sensor Circuit Insufficient Activity
* P0122 Throttle Position (TP) Sensor Circuit Low Voltage
* P0123 Throttle Position (TP) Sensor Circuit High Voltage
* P0124 Throttle Position Sensor 1 Circuit Intermittent
* P0125 Engine Coolant Temperature (ECT) Insufficient for Closed Loop Fuel Control
* P0126 Insufficient Engine Coolant Temperature for Stable Operation
* P0128 Coolant Thermostat
* P0130 HO2S Circuit Closed Loop (CL) Performance Bank 1 Sensor 1
* P0131 HO2S Circuit Low Voltage Bank 1 Sensor 1
* P0132 HO2S Circuit High Voltage Bank 1 Sensor 1
* P0133 HO2S Slow Response Bank 1 Sensor 1
* P0134 HO2S Circuit Insufficient Activity Bank 1 Sensor 1
* P0135 HO2S Heater Performance Bank 1 Sensor 1
* P0136 HO2S Circuit Bank 1 Sensor 2
* P0137 HO2S Circuit Low Voltage Bank 1 Sensor 2
* P0138 HO2S Circuit High Voltage Bank 1 Sensor 2
* P0139 HO2S Slow Response Bank 1 Sensor 2
* P0140 HO2S Circuit Insufficient Activity Bank 1 Sensor 2
* P0141 HO2S Heater Performance Bank 1 Sensor 2
MADDOG
MADDOG
* P0142 HO2S Circuit Bank 1 Sensor 3
* P0143 HO2S Circuit Low Voltage Bank 1 Sensor 3
* P0144 HO2S Circuit High Voltage Bank 1 Sensor 3
* P0145 HO2S Circuit Bank 1 Sensor 2 Slow Response
* P0146 HO2S Circuit Insufficient Activity Bank 1 Sensor 3
* P0147 HO2S Heater Performance Bank 1 Sensor 3
* P0150 HO2S Circuit Closed Loop (CL) Performance Bank 2 Sensor 1
* P0150 HO2S Circuit Bank 2 Sensor 1
* P0151 HO2S Circuit Low Voltage Bank 2 Sensor 1
* P0152 HO2S Circuit High Voltage Bank 2 Sensor 1
* P0153 HO2S Slow Response Bank 2 Sensor 1
* P0154 HO2S Circuit Insufficient Activity Bank 2 Sensor 1
* P0155 HO2S Heater Performance Bank 2 Sensor 1
* P0156 HO2S Circuit Bank 2 Sensor 2
* P0157 HO2S Circuit Low Voltage Bank 2 Sensor 2
* P0158 HO2S Circuit High Voltage Bank 2 Sensor 2
* P0159 HO2S Slow Response Bank 2 Sensor 2
* P0160 HO2S Circuit Insufficient Activity Bank 2 Sensor 2
* P0161 HO2S Heater Performance Bank 2 Sensor 2
* P0162 HO2S Circuit Bank 2 Sensor 3
* P0163 HO2S Circuit Bank 2 Sensor 3 Low Voltage
* P0164 HO2S Circuit Bank 2 Sensor 3 High Voltage
* P0165 HO2S Circuit Bank 2 Sensor 3 Slow Response
* P0166 HO2S Circuit Bank 2 Sensor 3 No Activity Detected
* P0167 HO2S Heater Circuit Bank 2 Sensor 3
* P0169 Fuel Composition Sensor
* P0170 Fuel Trim Bank 1
* P0171 Fuel Trim System Lean Bank 1
* P0172 Fuel Trim System Rich Bank 1
* P0173 Fuel Trim Bank 2
* P0174 Fuel Trim System Lean Bank 2
* P0175 Fuel Trim System Rich Bank 2
* P0176 Fuel Composition Sensor Circuit
* P0177 Fuel Composition Sensor Circuit Performance
* P0178 Fuel Composition Sensor Circuit Low Voltage
* P0179 Fuel Composition Sensor Circuit High Voltage
* P0180 Fuel Temperature Sensor 1 Circuit
* P0181 Fuel Temp. Sensor 1 Circuit Performance
* P0182 Fuel Temperature Sensor Circuit Low Voltage
* P0183 Fuel Temperature Sensor Circuit High Voltage
* P0184 Fuel Temperature Sensor 1 Circuit Intermittent
* P0185 Fuel Temperature Sensor 2 Circuit
* P0186 Fuel Temp. Sensor 2 Circuit Performance
* P0187 Fuel Temperature Sensor 2 Circuit Low Voltage
* P0188 Fuel Temperature Sensor 2 Circuit High Voltage
* P0189 Fuel Temperature Sensor 2 Circuit Intermittent
* P0190 Fuel Rail Pressure Sensor Circuit
* P0191 Fuel Rail Pressure Sensor Circuit Performance
* P0192 Fuel Rail Pressure Sensor Circuit Low Voltage
* P0193 Fuel Rail Pressure Sensor Circuit High Voltage
* P0194 Fuel Rail Pressure Sensor Circuit Intermittent
* P0195 Engine Oil Temperature Sensor
* P0196 Engine Oil Temperature Sensor Performance
* P0197 Engine Oil Temperature Sensor Low Voltage
* P0198 Engine Oil Temperature Sensor High Voltage
* P0199 Engine Oil Temperature Sensor Intermittent
* P0200 Injector Control Circuit
* P0201 Injector 1 Control Circuit
* P0202 Injector 2 Control Circuit
* P0203 Injector 3 Control Circuit
* P0204 Injector 4 Control Circuit
* P0205 Injector 5 Control Circuit
* P0206 Injector 6 Control Circuit
* P0207 Injector 7 Control Circuit
* P0208 Injector 8 Control Circuit
* P0209 Injector 9 Control Circuit
* P0210 Injector 10 Control Circuit
* P0211 Injector 11 Control Circuit
* P0212 Injector 12 Control Circuit
* P0213 Cold Start Injector 1
* P0214 Cold Start Injector 2
* P0215 Engine Shutoff Control Circuit
* P0216 Injection Timing Control Circuit
* P0217 Engine Overtemp Condition
* P0218 Transmission Fluid Overtemperature
* P0219 Engine Overspeed Condition
* P0220 APP Sensor 2 Circuit
* P0221 APP (Throttle Position) Sensor 2 Circuit Performance
* P0222 APP (Throttle Position) Sensor 2 Circuit Low Voltage
* P0223 APP (Throttle Position) Sensor 2 Circuit High Voltage
* P0224 Throttle Position Sensor 2 Intermittent
* P0225 APP Sensor 3 Circuit
* P0226 APP Sensor 3 Circuit Performance
* P0227 APP Sensor 3 Circuit Low Voltage
* P0228 APP Sensor 3 Circuit High Voltage
* P0229 Throttle Position Sensor 3 Intermittent
* P0230 Fuel Pump Relay Control Circuit
* P0231 Fuel Pump Feedback Circuit Low Voltage
* P0232 Fuel Pump Feedback Circuit High Voltage
* P0233 Fuel Pump Secondary Circuit Intermittent
* P0234 TC Engine Overboost Condition
* P0235 Turbocharger Boost Sensor 1 Circuit
* P0236 TC Boost System
* P0237 TC Boost Sensor Circuit Low Voltage
* P0238 TC Boost Sensor Circuit High Voltage
* P0239 Turbocharger Boost Sensor 2 Circuit
* P0240 Turbocharger Boost Sensor 2 Performance
* P0241 Turbocharger Boost Sensor 2 Circuit Low Voltage
* P0242 Turbocharger Boost Sensor 2 Circuit High Voltage
* P0243 Turbocharger Wastegate Solenoid 1
* P0244 Turbocharger Wastegate Solenoid 1 Performance
* P0245 Turbocharger Wastegate Solenoid 1 Low Voltage
* P0246 Turbocharger Wastegate Solenoid 1 High Voltage
* P0247 Turbocharger Wastegate Solenoid 2
* P0248 Turbocharger Wastegate Solenoid 2 Performance
* P0249 Turbocharger Wastegate Solenoid 2 Low Voltage
* P0250 Turbocharger Wastegate Solenoid 2 High Voltage
* P0251 Injection Pump Fuel Metering Control "A" Malfunction (Cam/Rotor/Injector)
* P0252 Injection Pump Fuel Metering Control "A" Range/Performance (Cam/Rotor/Injector)
* P0253 Injection Pump Fuel Metering Control "A" Low (Cam/Rotor/Injector)
* P0254 Injection Pump Fuel Metering Control "A" High (Cam/Rotor/Injector)
* P0255 Injection Pump Fuel Metering Control "A" Intermittent (Cam/Rotor/Injector)
* P0256 Injection Pump Fuel Metering Control "B" Malfunction (Cam/Rotor/Injector)
* P0257 Injection Pump Fuel Metering Control "B" Range/Performance (Cam/Rotor/Injector)
* P0258 Injection Pump Fuel Metering Control "B" Low (Cam/Rotor/Injector)
* P0259 Injection Pump Fuel Metering Control "B" High (Cam/Rotor/Injector)
* P0260 Injection Pump Fuel Metering Control "B" Intermittent (Cam/Rotor/Injector)
* P0261 Cylinder 1 Injector Circuit Low
* P0262 Cylinder 1 Injector Circuit High
* P0263 Cylinder 1 Contribution/Balance Fault
* P0264 Cylinder 2 Injector Circuit Low
* P0265 Cylinder 2 Injector Circuit High
* P0266 Cylinder 2 Contribution/Balance Fault
* P0267 Cylinder 3 Injector Circuit Low
* P0268 Cylinder 3 Injector Circuit High
* P0269 Cylinder 3 Contribution/Balance Fault
* P0270 Cylinder 4 Injector Circuit Low
* P0271 Cylinder 4 Injector Circuit High
* P0272 Cylinder 4 Contribution/Balance Fault
* P0273 Cylinder 5 Injector Circuit Low
* P0274 Cylinder 5 Injector Circuit High
* P0275 Cylinder 5 Contribution/Balance Fault
* P0276 Cylinder 6 Injector Circuit Low
* P0277 Cylinder 6 Injector Circuit High
* P0278 Cylinder 6 Contribution/Balance Fault
* P0279 Cylinder 7 Injector Circuit Low
* P0280 Cylinder 7 Injector Circuit High
MADDOG
MADDOG
* P0281 Cylinder 7 Contribution/Balance Fault
* P0282 Cylinder 8 Injector Circuit Low
* P0283 Cylinder 8 Injector Circuit High
* P0284 Cylinder 8 Contribution/Balance Fault
* P0285 Cylinder 9 Injector Circuit Low
* P0286 Cylinder 9 Injector Circuit High
* P0287 Cylinder 9 Contribution/Balance Fault
* P0288 Cylinder 10 Injector Circuit Low
* P0289 Cylinder 10 Injector Circuit High
* P0290 Cylinder 10 Contribution/Balance Fault
* P0291 Cylinder 11 Injector Circuit Low
* P0292 Cylinder 11 Injector Circuit High
* P0293 Cylinder 11 Contribution/Balance Fault
* P0294 Cylinder 12 Injector Circuit Low
* P0295 Cylinder 12 Injector Circuit High
* P0296 Cylinder 12 Contribution/Range Fault
* P0300 Engine Misfire Detected
* P0301 Cylinder 1 Misfire Detected
* P0302 Cylinder 2 Misfire Detected
* P0303 Cylinder 3 Misfire Detected
* P0304 Cylinder 4 Misfire Detected
* P0305 Cylinder 5 Misfire Detected
* P0306 Cylinder 6 Misfire Detected
* P0307 Cylinder 7 Misfire Detected
* P0308 Cylinder 8 Misfire Detected
* P0309 Cylinder 9 Misfire Detected
* P0311 Cylinder 11 Misfire Detected
* P0312 Cylinder 12 Misfire Detected
* P0313 Misfire Detected With Low Fuel Level
* P0318 Rough Road Sensor Circuit
* P0320 Ignition/Distributor Engine Speed Input Circuit Malfunction
* P0321 Ignition/Distributor Engine Speed Input Circuit Range/Performance
* P0322 IC Module 4X Reference CKT No Frequency
* P0323 Ignition/Distributor Engine Speed Input Circuit Intermittent
* P0324 Knock Sensor (KS) Module Performance
* P0325 PCM Knock Sensor Circuit
* P0326 Knock Sensor CKT Excessive Spark Retard
* P0327 Knock Sensor Circuit Low Voltage
* P0328 Knock Sensor 1 Circuit High Input (Bank 1 or Single Sensor)
* P0329 Knock Sensor 1 Circuit Intermittent (Bank 1 or Single Sensor)
* P0330 Knock Sensor (KS) Circuit Bank 2
* P0331 Knock Sensor 2 Circuit Range/Performance (Bank 2)
* P0332 Knock Sensor 2 Circuit Low Input (Bank 2)
* P0333 Knock Sensor 2 Circuit High Input (Bank 2)
* P0334 Knock Sensor 2 Circuit Intermittent (Bank 2)
* P0335 CKP Sensor A Circuit Performance
* P0336 Crankshaft Position (CKP) Sensor A Performance
* P0337 Crankshaft Position (CKP) Sensor Circuit Low Duty Cycle
* P0338 Crankshaft Position (CKP) Sensor Circuit High Duty Cycle
* P0339 Crankshaft Position (CKP) Sensor Circuit Intermittent
* P0340 Camshaft Position (CMP) Sensor Circuit
* P0341 Camshaft Position (CMP) Sensor Performance
* P0342 Camshaft Position Sensor Circuit Low Input
* P0343 Camshaft Position Sensor Circuit High Input
* P0344 Camshaft Position Sensor Circuit Intermittent
* P0350 Ignition Coil Primary/Secondary Circuit Malfunction
* P0351 Ignition Coil 1 Control Circuit
* P0352 Ignition Coil 2 Control Circuit
* P0353 Ignition Coil 3 Control Circuit
* P0354 Ignition Coil 4 Control Circuit
* P0355 Ignition Coil 5 Control Circuit
* P0356 Ignition Coil 6 Control Circuit
* P0357 Ignition Coil 7 Control Circuit
* P0358 Ignition Coil 8 Control Circuit
* P0359 Ignition Coil I Primary/Secondary Circuit Malfunction
* P0360 Ignition Coil J Primary/Secondary Circuit Malfunction
* P0361 Ignition Coil K Primary/Secondary Circuit Malfunction
* P0362 Ignition Coil L Primary/Secondary Circuit Malfunction
* P0370 Timing Reference High Resolution Signal A Malfunction
* P0371 IC 24X Reference CKT Too Many Pulses
* P0372 IC 24X Reference Circuit Missing Pulses
* P0373 Timing Reference High Resolution Signal A Intermittent/Erratic Pulses
* P0374 Timing Reference High Resolution Signal A No Pulses
* P0375 Timing Reference High Resolution Signal B Malfunction
MADDOG
MADDOG
* P0376 Timing Reference High Resolution Signal B Too Many Pulses
* P0377 Timing Reference High Resolution Signal B Too Few Pulses
* P0378 Timing Reference High Resolution Signal B Intermittent/Erratic Pulses
* P0379 Timing Reference High Resolution Signal B No Pulses
* P0380 Glow Plug/Heater Circuit "A" Malfunction
* P0381 Glow Plug/Heater Indicator Circuit Malfunction
* P0382 Exhaust Gas Recirculation Flow Malfunction
* P0385 Crankshaft Position (CKP) Sensor B Circuit
* P0386 Crankshaft Position (CKP) Sensor B Performance
* P0387 Crankshaft Position Sensor B Circuit Low Input
* P0388 Crankshaft Position Sensor B Circuit High Input
* P0389 Crankshaft Position Sensor B Circuit Intermittent
* P0400 Exhaust Gas Recirculation Flow Malfunction
* P0401 Exhaust Gas Recirculation (EGR) Flow Insufficient
* P0402 Exhaust Gas Recirculation Flow Excessive Detected
* P0403 Exhaust Gas Recirculation (EGR) Solenoid Control Circuit
* P0404 Exhaust Gas Recirculation (EGR) Open Position Performance
* P0405 Exhaust Gas Recirculation (EGR) Position Sensor Circuit Low Voltage
* P0406 Exhaust Gas Recirculation Sensor A Circuit High
* P0407 Exhaust Gas Recirculation Sensor B Circuit Low
* P0408 Exhaust Gas Recirculation Sensor B Circuit High
* P0410 Secondary Air Injection (AIR) System
* P0411 Secondary Air Injection (AIR) System
* P0412 Secondary Air Injection (AIR) Solenoid Relay Control Circuit Bank 1
* P0413 Secondary Air Injection System Switching Valve A Circuit Open
* P0414 Secondary Air Injection System Switching Valve A Circuit Shorted
* P0415 Secondary Air Injection System Switching Valve B Circuit Malfunction
* P0416 Secondary Air Injection System Switching Valve B Circuit Open
* P0417 Secondary Air Injection System Switching Valve B Circuit Shorted
* P0418 Secondary Air Injection (AIR) Pump Relay Control Circuit Bank 1
* P0419 Secondary Air Injection (AIR) Pump Relay Control Circuit Bank 2
* P0420 Catalyst System Low Efficiency
* P0421 Warm Up Catalyst Efficiency Below Threshold (Bank 1)
* P0422 Catalyst System Low Efficiency Bank 1
* P0423 Heated Catalyst Efficiency Below Threshold (Bank 1)
* P0424 Heated Catalyst Temperature Below Threshold (Bank 1)
* P0430 Catalyst System Low Efficiency Bank 2
* P0431 Warm Up Catalyst Efficiency Below Threshold (Bank 2)
* P0432 Catalyst System Low Efficiency Bank 2
* P0433 Heated Catalyst Efficiency Below Threshold (Bank 2)
* P0434 Heated Catalyst Temperature Below Threshold (Bank 2)
* P0440 Evaporative Emission (EVAP) System
* P0441 Evaporative Emission Control System Incorrect Purge Flow
* P0442 Evaporative Emission (EVAP) System Small Leak Detected (often this is a loose or bad gas cap!)
* P0443 EVAP Purge Solenoid Valve 1 Control CKT
* P0444 Evaporative Emission Control System Purge Control Valve Circuit Open
* P0445 Evaporative Emission Control System Purge Control Valve Circuit Shorted
* P0446 EVAP Vent Solenoid Valve Control System
* P0447 Evaporative Emission Control System Vent Control Circuit Open
* P0448 Evaporative Emission Control System Vent Control Circuit Shorted
* P0449 Evaporative Emission (EVAP) Vent Solenoid Control Circuit
* P0450 Fuel Tank Pressure Sensor Circuit
* P0451 Evaporative Emission Control System Pressure Sensor Range/Performance
* P0452 Fuel Tank Pressure Sensor Circuit Low Voltage
* P0453 Fuel Tank Pressure Sensor Circuit High Voltage
* P0454 Evaporative Emission Control System Pressure Sensor Intermittent
* P0455 Evaporative Emission (EVAP) System Leak Detected
* P0460 Fuel Level Sensor Circuit
* P0461 Fuel Level Sensor Performance
* P0462 Fuel Level Sensor Circuit Low Voltage
* P0463 Fuel Level Sensor Circuit High Voltage
* P0464 Fuel Level Sensor Circuit Intermittent
* P0465 Purge Flow Sensor Circuit Malfunction
* P0466 Purge Flow Sensor Circuit Range/Performance
* P0467 Purge Flow Sensor Circuit Low Input
* P0468 Purge Flow Sensor Circuit High Input
* P0469 Purge Flow Sensor Circuit Intermittent
* P0470 Exhaust Pressure Sensor Malfunction
* P0471 Exhaust Pressure Sensor Range/Performance
* P0472 Exhaust Pressure Sensor Low
* P0473 Exhaust Pressure Sensor High
* P0474 Exhaust Pressure Sensor Intermittent
* P0475 Exhaust Pressure Control Valve Malfunction
* P0476 Exhaust Pressure Control Valve Range/Performance
* P0477 Exhaust Pressure Control Valve Low
* P0478 Exhaust Pressure Control Valve High
* P0479 Exhaust Pressure Control Valve Intermittent
* P0480 Cooling Fan Relay 1 Control Circuit
* P0481 Cooling Fan Relay 2 Control Circuit
* P0482 Cooling Fan 3 Control Circuit Malfunction
* P0483 Cooling Fan Rationality Check Malfunction
* P0484 Cooling Fan Circuit Over Current
* P0485 Cooling Fan Power/Ground Circuit Malfunction
* P0496 Evaporative Emission (EVAP) System Flow During Non-Purge
* P0500 Vehicle Speed Sensor (VSS) Circuit
* P0501 Vehicle Speed Sensor Range/Performance
* P0502 Vehicle Speed Sensor (VSS) Circuit Low Input
MADDOG
MADDOG
* P0503 Vehicle Speed Sensor (VSS) Circuit Intermittent
* P0505 Idle Control System Malfunction
* P0506 Idle Speed Low
* P0507 Idle Speed High
* P0510 Closed Throttle Position Switch Malfunction
* P0512 Start Switch Circuit
* P0520 Engine Oil Pressure Sensor/Switch Circuit Malfunction
* P0521 Engine Oil Pressure Sensor/Switch Circuit Range/Performance
* P0522 Engine Oil Pressure Sensor/Switch Circuit Low Voltage
* P0523 Engine Oil Pressure Sensor/Switch Circuit High Voltage
* P0530 A/C Refrigerant Pressure Sensor Circuit Malfunction
* P0531 A/C Refrigerant Pressure Sensor Circuit Range/Performance
* P0532 Air Conditioning (A/C) Refrigerant Pressure Sensor Circuit Low Voltage
* P0533 Air Conditioning (A/C) Refrigerant Pressure Sensor Circuit High Voltage
* P0534 Air Conditioner Refrigerant Charge Loss
* P0550 Power Steering Pressure (PSP) Switch Circuit
* P0551 Power Steering Pressure Sensor Circuit Range/Performance
* P0552 Power Steering Pressure Sensor Circuit Low Input
* P0553 Power Steering Pressure Sensor Circuit High Input
* P0554 Power Steering Pressure Sensor Circuit Intermittent
* P0560 System Voltage
* P0561 System Voltage Unstable
* P0562 System Voltage Low
* P0563 System Voltage High
* P0565 Cruise Control On Signal Malfunction
* P0566 Cruise Control Off Signal Malfunction
* P0567 Cruise Control Resume Signal Malfunction
* P0568 Cruise Control Set Signal Malfunction
* P0569 Cruise Control Coast Signal Malfunction
* P0570 Cruise Control Accel Signal Malfunction
* P0571 Cruise Control Brake Switch Circuit
* P0573 Cruise Control/Brake Switch A Circuit High
* P0574 Vehicle Speed Too High - Cruise Control Disabled
* P0575 Cruise Control Related Malfunction
* P0576 Cruise Control Related Malfunction
* P0578 Cruise Control Related Malfunction
* P0579 Cruise Control Related Malfunction
* P0580 Cruise Control Related Malfunction
* P0600 Serial Communication Link Malfunction
* P0601 Control Module Read Only Memory (ROM)
* P0602 Control Module Not Programmed
* P0603 Control Module Long Term Memory Reset
* P0604 Control Module Random Access Memory (RAM)
* P0605 Control Module Programming Read Only Memory (ROM)
* P0606 Control Module Internal Performance
* P0607 ECU Malfunction
* P0608 Control Module VSS Output "A" Malfunction
* P0609 Control Module VSS Output "B" Malfunction
* P0610 Control Module Vehicle Options Incorrect
* P0615 Starter Relay Control Circuit
* P0616 Starter Relay Control Circuit Low Voltage
* P0617 Starter Relay Control Circuit High Voltage
* P0620 Generator Control Circuit Malfunction
* P0621 Generator L-Terminal Circuit
* P0622 Generator F-Terminal Circuit
* P0625 Generator F-Terminal Circuit Low Voltage
* P0626 Generator F-Terminal Circuit High Voltage
* P0628 Fuel Pump Relay Control Circuit Low Voltage
* P0629 Fuel Pump Relay Control Circuit High Voltage
* P0638 Throttle Actuator Control (TAC) Command Performance
* P0645 Air Conditioning (A/C) Clutch Relay Control Circuit
* P0646 Air Conditioning (A/C) Clutch Relay Control Circuit
* P0647 Air Conditioning (A/C) Clutch Relay Control Circuit
* P0650 Malfunction Indicator Lamp (MIL) Control Circuit
* P0654 Engine RPM Output Circuit Malfunction
* P0655 Engine Hot Lamp Output Control Circuit Malfucntion
* P0656 Fuel Level Output Circuit Malfunction
* P0660 Intake Manifold Tuning (IMT) Valve Solenoid Control Circuit
* P0661 Intake Manifold Tuning (IMT) Valve Solenoid Control Circuit Low Voltage
* P0662 Intake Manifold Tuning (IMT) Valve Solenoid Control Circuit High Voltage
* P0691 Cooling Fan Relay Control Circuit Low Voltage
* P0693 Cooling Fan Relay Control Circuit Low Voltage
* P0692 Cooling Fan Relay Control Circuit High Voltage
* P0694 Cooling Fan Relay Control Circuit High Voltage
* P0700 Transmission Control System Malfunction
* P0701 Transmission Control System Range/Performance
* P0702 Transmission Control System Electrical
* P0703 Brake Switch Circuit Malfunction
MADDOG
MADDOG
* P0704 Clutch Switch Input Circuit Malfunction
* P0705 Trans Range Switch Circuit
* P0706 Trans Range Switch Performance
* P0707 Transmission Range Sensor Circuit Low Input
* P0708 Transmission Range Sensor Circuit High Input
* P0709 Transmission Range Sensor Circuit Intermittent
* P0710 Transmission Fluid Temperature Sensor Circuit Malfunction
* P0711 TFT Sensor Circuit Range/Performance
* P0712 Transmission Fluid Temperature (TFT) Sensor Circuit Low Input
* P0713 Transmission Fluid Temperature (TFT) Sensor Circuit High Input
* P0714 Transmission Fluid Temperature Sensor Circuit Intermittent
* P0715 Input/Turbine Speed Sensor Circuit Malfunction
* P0716 Input Speed Sensor Circuit Intermittent
* P0717 Input Speed Sensor Circuit Low Input
* P0718 Input/Turbine Speed Sensor Circuit Intermittent
* P0719 Brake Switch Circuit Low Input
* P0720 Output Speed Sensor Circuit Malfunction
* P0721 Output Speed Sensor Range/Performance
* P0722 Output Speed Sensor Circuit Low Input
* P0723 Output Speed Sensor Intermittent
* P0724 Brake Switch Circuit High Input
* P0725 Engine Speed Input Circuit
* P0726 Engine Speed Input Circuit Range/Performance
* P0727 Engine Speed Circuit No Signal
* P0728 Engine Speed Input Circuit Intermittent
* P0730 Incorrect Gear Ratio
* P0731 Incorrect 1st Gear Ratio
MADDOG
MADDOG
* P0732 Incorrect 2nd Gear Ratio
* P0733 Incorrect 3rd Gear Ratio
* P0734 Incorrect 4th Gear Ratio
* P0735 Gear 5 Incorrect ratio
* P0736 Reverse incorrect gear ratio
* P0740 TCC Enable Solenoid Circuit Electrical
* P0741 TCC System Stuck Off
* P0742 TCC System Stuck On
* P0743 TCC Enable Solenoid Circuit Electrical
* P0744 Torque Converter Clutch Circuit Intermittent
* P0745 Pressure Control Solenoid Malfunction
* P0746 Pressure Control Solenoid Performance or Stuck Off
* P0747 Pressure Control Solenoid Stuck On
* P0748 Pressure Control Solenoid Circuit Electrical
* P0749 Pressure Control Solenoid Intermittent
* P0750 Shift Solenoid A Malfunction
* P0751 1-2 Shift Solenoid Valve Performance - No First or Fourth Gear
* P0752 1-2 Shift Solenoid Valve Performance - No Second or Third Gear
* P0753 1-2 Shift Solenoid Circuit Electrical
* P0754 Shift Solenoid A Intermittent
* P0755 Shift Solenoid B Malfunction
* P0756 2-3 Shift Solenoid Valve Performance - No First or Second Gear
* P0757 2-3 Shift Solenoid Valve Performance - No Third or Fourth Gear
* P0758 2-3 Shift Solenoid Circuit Electrical
* P0759 Shift Solenoid B Intermittent
* P0760 Shift Solenoid C Malfunction
* P0761 Shift Solenoid C Performance or Stuck Off
* P0762 Shift Solenoid C Stuck On
* P0763 Shift Solenoid C Electrical
* P0764 Shift Solenoid C Intermittent
* P0765 Shift Solenoid D Malfunction
* P0766 Shift Solenoid D Performance or Stuck Off
* P0767 Shift Solenoid D Stuck On
* P0768 Shift Solenoid D Electrical
* P0769 Shift Solenoid D Intermittent
* P0770 Shift Solenoid E Malfunction
* P0771 Shift Solenoid E Performance or Stuck Off
* P0772 Shift Solenoid E Stuck On
* P0773 Shift Solenoid E Electrical
* P0774 Shift Solenoid E Intermittent
* P0780 Shift Malfunction
* P0781 1-2 Shift Malfunction
* P0782 2-3 Shift Malfunction
* P0783 3-4 Shift Malfunction
* P0784 4-5 Shift Malfunction
* P0785 3-2 Shift Solenoid Circuit Electrical
* P0786 Shift/Timing Solenoid Range/Performance
* P0787 Shift/Timing Solenoid Low
* P0788 Shift/Timing Solenoid High
* P0789 Shift/Timing Solenoid Intermittent
* P0790 Normal/Performance Switch Circuit Malfunction
* P0801 Reverse Inhibit Control Circuit Malfunction
* P0803 1-4 Upshift (Skip Shift) Solenoid Control Circuit Malfunction
* P0804 1-4 Upshift (Skip Shift) Lamp Control Circuit Malfunction
* P0850 Park/Neutral Position (PNP) Switch Circuit
* P0856 Powertrain Indicated Traction Control Malfunction
* P1031 HO2S Heater Current Monitor Control Circuit Banks 1 and 2 Sensor 1
* P1032 HO2S Heater Warm Up Control Circuit Banks 1 and 2 Sensor 1
* P1105 Secondary Vacuum Sensor Circuit
* P1106 Manifold Absolute Pressure (MAP) Sensor Circuit Intermittent High Voltage
* P1107 Manifold Absolute Pressure (MAP) Sensor Circuit Intermitten
* P1108 BARO to MAP Sensor Comparison Too High
* P1109 Secondary Port Throttle System
* P1111 Intake Air Temperature (IAT) Sensor Circuit Intermittent High Voltage
* P1112 Intake Air Temperature (IAT) Sensor Circuit Intermittent Low Voltage
* P1113 Intake Resonance Switchover Solenoid Control Circuit
* P1114 Engine Coolant Temperature (ECT) Sensor Circuit Intermittent Low Voltage
* P1115 Engine Coolant Temperature (ECT) Sensor Circuit Intermittent High Voltage
* P1116 ECT Signal Unstable or Intermittent
* P1117 Engine Coolant Temp. Signal Out-Of-Range Low
* P1118 Engine Coolant Temp. Signal Out-Of-Range High
* P1119 ECT Signal Out-Of-Range With TFT Sensor
* P1120 Throttle Position (TP) Sensor 1 Circuit
* P1121 Throttle Position (TP) Sensor Circuit Intermittent High Voltage
* P1122 Throttle Position (TP) Sensor Circuit Intermittent Low Voltage
* P1125 APP System
* P1130 HO2S Circuit Low Variance Bank 1 Sensor 1
* P1131 HO2S Circuit Low Variance Bank 1 Sensor 2
* P1132 HO2S Circuit Low Variance Bank 2 Sensor 1
* P1133 HO2S Insufficient Switching Bank 1 Sensor 1
* P1134 HO2S Transition Time Ratio Bank 1 Sensor 1
* P1135 HO2S Lean Mean Bank 1 Sensor 1
* P1136 HO2S Rich Mean Bank 1 Sensor 1
* P1137 HO2S Bank 1 Sensor 2 Lean System or Low Voltage
* P1138 HO2S Bank 1 Sensor 2 Rich or High Voltage
* P1139 HO2S Insuff. Switching Bank 1 Sensor 2
* P1140 HO2S Transition Time Ratio Bank 1 Sensor 2
* P1141 HO2S Heater Control Circuit Bank 1 Sensor 2
* P1143 HO2S Bank 1 Sensor 3 Lean System or Low Voltage
* P1144 HO2S Bank 1 Sensor 3 Rich or High Voltage
* P1145 HO2S Cross Counts Bank 1 Sensor 3
* P1153 HO2S Insufficient Switching Bank 2 Sensor 1
* P1154 HO2S Transition Time Ratio Bank 2 Sensor 1
* P1155 HO2S Lean Mean Bank 2 Sensor 1
* P1156 HO2S Rich Mean Bank 2 Sensor 1
* P1157 HO2S Bank 2 Sensor 2 Lean System or Low Voltage
* P1158 HO2S Bank 2 Sensor 2 Rich or High Voltage
* P1159 HO2S Cross Counts Bank 2 Sensor 2
* P1161 HO2S Heater Control Circuit Bank 2 Sensor 2
* P1163 HO2S Bank 2 Sensor 3 Lean System or Low Voltage
* P1164 HO2S Bank 2 Sensor 3 Rich or High Voltage
* P1165 HO2S Cross Counts Bank 2 Sensor 3
* P1170 Bank to Bank Fuel TrimOffset
* P1171 Fuel System Lean During Acceleration
* P1172 Fuel Transfer Pump Flow Insufficient
* P1185 Engine Oil Temperature Circuit
* P1186 EOT Circuit Performance
* P1187 EOT Sensor Ckt. Low Voltage
* P1188 EOT Sensor Ckt. High Voltage
* P1189 Engine Oil Pressure (EOP) Switch Circuit
* P1190 Engine Vacuum Leak
* P1191 Intake Air Duct Air Leak
* P1200 Injector Control Circuit
* P1201 (Alt. Fuel) Gas Mass Sensor Circuit Range/Performance
* P1202 (Alt. Fuel) Gas Mass Sensor Circuit Low Frequency
* P1203 (Alt. Fuel) Gas Mass Sensor Circuit High Frequency
* P1211 Mass Air Flow Circuit Intermittent High
* P1212 Mass Air Flow Circuit Intermittent Low
* P1214 Injection Pump Timing Offset
* P1215 Ground Fault Detection Indicated
* P1216 Fuel Solenoid Response Time Too Short
* P1217 Fuel Solenoid Response Time Too Long
MADDOG
MADDOG
* P1218 Injection Pump Calibration Circuit
* P1219 Throttle Position Sensor Reference Voltage
* P1220 Throttle Position (TP) Sensor 2 Circuit
* P1221 Fuel Pump Secondary Circuit Low
* P1222 Injector Control Circuit Intermittent
* P1225 Injector Circuit Cylinder 2 Intermittent
* P1228 Injector Circuit Cylinder 3 Intermittent
* P1231 Injector Circuit Cylinder 4 Intermittent
* P1234 Injector Circuit Cylinder 5 Intermittent
* P1237 Injector Circuit Cylinder 6 Intermittent
* P1240 Injector Circuit Cylinder 7 Intermittent
* P1243 Injector Circuit Cylinder 8 Intermittent
* P1245 Intake Plenum Switchover Valve
* P1250 Early Fuel Evaporation Heater Circuit
* P1257 Supercharger System Overboost
* P1258 Engine Coolant Overtemperature - Protection Mode Active
* P1260 Last Test Failed Failed SCC ENTER:More Info.
* P1270 Accelerator Pedal Position Sensor A/D Converter Error
* P1271 Accelerator Pedal Position (APP) Sensor 1-2 Correlation
* P1272 Accelerator Pedal Position Sensor 2
* P1273 "Accelerator Pedal Position Sensor 1
* P1274 Injectors Wired Incorrectly
* P1275 Accelerator Pedal Position (APP) Sensor 1 Circuit
* P1276 Accelerator Pedal Position Sensor 1 Circuit Performance
* P1277 Accelerator Pedal Position Sensor 1 Circuit Low Voltage
* P1278 Accelerator Pedal Position Sensor 1 Circuit High Voltage
* P1280 Accelerator Pedal Position (APP) Sensor 2 Circuit
* P1281 Accelerator Pedal Position Sensor 2 Circuit Performance
* P1282 Accelerator Pedal Position Sensor 2 Circuit Low Voltage
* P1283 Accelerator Pedal Position Sensor 2 Circuit High Voltage
* P1285 Accelerator Pedal Position Sensor 3 Circuit
* P1286 Accelerator Pedal Position Sensor 3 Circuit Performance
* P1287 Accelerator Pedal Position Sensor 3 Circuit Low Voltage
* P1288 Accelerator Pedal Position Sensor 3 Circuit High Voltage
* P1300 Ignitor Circuit
* P1305 Ignition Coil 2 Primary Feedback Circuit
* P1310 Ignition Coil 3 Primary Feedback Circuit
* P1315 Ignition Coil 4 Primary Feedback Circuit
* P1320 IC 4X Reference Circuit Intermittent
* P1321 Electronic Ignition System Fault Line
* P1322 EI System or Ignition Control Extra or Missing
* P1323 IC 24X Reference Circuit Low Frequency
* P1324 Crank RPM Too Low
* P1335 CKP Circuit
* P1336 Crankshaft Position (CKP) System Variation Not Learned
* P1345 Crankshaft Position (CKP)-Camshaft Position (CMP) Correlation
* P1346 Intake Camshaft Position [CMP] Sensor System Performance
* P1350 Ignition Control System
* P1351 Ignition Coil Control Circuit High Voltage
* P1352 IC Output High/Pulse Detected when GND_Cyl. 2
* P1353 IC Output High/Pulse Detected when GND_Cyl. 3
* P1354 IC Output High/Pulse Detected when GND_Cyl. 4
* P1355 IC Output High/Pulse Detected when GND_Cyl. 5
* P1356 IC Output High/Pulse Detected when GND_Cyl. 6
* P1357 IC Output High/Pulse Detected when GND_Cyl. 7
* P1358 IC Output High/Pulse Detected when GND_Cyl. 8
* P1359 Ignition Coil Group 1 Control Circuit
* P1360 Ignition Coil Group 2 Control Circuit
* P1361 Ignition Coil Control Circuit Low Voltage
* P1362 IC Cylinder 2 Not Toggling After Enable
* P1363 IC Cylinder 3 Not Toggling After Enable
* P1364 IC Cylinder 4 Not Toggling After Enable
* P1365 IC Cylinder 5 Not Toggling After Enable
* P1366 IC Cylinder 6 Not Toggling After Enable
* P1367 IC Cylinder 7 Not Toggling After Enable
* P1368 IC Cylinder 8 Not Toggling After Enable
* P1370 IC 4X Reference Circuit Too Many Pulses
* P1371 IC 4X Reference Circuit Too Few Pulses
* P1372 Crankshaft Position (CKP) Sensor A-B Correlation
* P1374 3X Reference Circuit
* P1375 IC 24X Reference Circuit High Voltage
* P1376 Ignition Ground Circuit
* P1377 IC Cam Pulse To 4X Reference Pulse
* P1380 Misfire Detected - Rough Road Data Not Available
* P1381 Misfire Detected - No Communication with Brake Control Module
* P1390 Wheel Speed Sensor 1 - G - Sensor Circuit
* P1391 Wheel Speed Sensor 1 - G - Sensor Circuit Performance
* P1392 Wheel Speed Sensor 1 - G - Sensor Circuit Low Voltage
* P1393 Wheel Speed Sensor 1 - G - Sensor Circuit High Voltage
* P1394 Wheel Speed Sensor 1 - G - Sensor Circuit Intermittent
* P1395 Wheel Speed Sensor 2 - G - Sensor Circuit
* P1396 Wheel Speed Sensor 2 - G - Sensor Circuit Performance
* P1397 Wheel Speed Sensor 2 - G - Sensor Circuit Low Voltage
* P1398 Wheel Speed Sensor 2 - G - Sensor Circuit High Voltage
* P1399 Wheel Speed Sensor 2 - G - Sensor Circuit Intermittent
* P1403 Exhaust Gas Recirculation System Valve 1
* P1404 Exhaust Gas Recirculation (EGR) Closed Position Performance
* P1405 Exhaust Gas Recirculation System Valve 3
* P1406 EGR Valve Pintle Position Circuit
* P1407 EGR Air Intrusion in Exhaust Supply to EGR Valve
* P1408 Intake Manifold Pressure Sensor Circuit
* P1409 EGR Vacuum System Leak
* P1410 Fuel Tank Pressure System
* P1415 Secondary Air Injection (AIR) System Bank 1
* P1416 Secondary Air Injection (AIR) System Bank 2
* P1418 Secondary Air Injection System Relay A Control Circuit High
* P1420 Intake Air Low Pressure Switch Circuit Low Voltage
* P1421 Intake Air Low Pressure Switch Circuit High Voltage
* P1423 Intake Air High Pressure Switch Circuit High Voltage
* P1431 Fuel Level Sensor 2 Circuit Performance
* P1432 Fuel Level Sensor 2 Circuit Low Voltage
* P1433 Fuel Level Sensor 2 Circuit High Voltage
* P1441 Evaporative Emission (EVAP) System Flow During Non-Purge
* P1442 EVAP Vacuum Sw. High Voltage During Ign. On
* P1450 Barometric Pressure Sensor Circuit
* P1451 Barometric Press. Sensor Performance
* P1460 Cooling Fan Control System
* P1460 Misfire Detected With Low Fuel Level
* P1480 Cooling Fan 1 Control Circuit High
* P1483 Engine Cooling System Performance
* P1500 Starter Signal Circuit
* P1501 Theft Deterrent System
* P1501 Vehicle Speed Sensor Circuit Intermittent
* P1502 Theft Deterrent Fuel Enable Signal Not Received
* P1503 Theft Deterrent Fuel Enable Signal Not Correct
* P1504 Vehicle Speed Output Circuit
* P1508 Idle Speed Low - Idle Air Control (IAC) System Not Responding
* P1509 Idle Speed High - Idle Air Control (IAC) System Not Responding
* P1510 Throttle Control System Performance - Throttle Limitation Active
* P1511 Throttle Control System - Backup System Performance
* P1514 Airflow to TP Sensor Correlation High
* P1515 Electronic Throttle System Throttle Position
* P1516 Throttle Actuator Control (TAC) Module Throttle Actuator Position Performance
* P1517 Electronic Throttle Module
* P1518 Electronic Throttle Module to PCM Communication
* P1519 Throttle Actuator Control (TAC) Module Internal Circuit
* P1520 Transmission Range Switch Circuit
* P1521 Transmission Engaged at High Throttle Angle
* P1522 Park/Neutral to Drive/Reverse at High RPM
* P1523 Throttle Closed Position Performance
* P1524 Throttle Closed Position Performance
* P1525 Throttle Body ServiceRequired
* P1526 Minimum Throttle Position Not Learned
* P1527 Transmission Range to Pressure Switch Correlation
* P1528 Governor
* P1529 Heated Windshield Request Problem
* P1530 Throttle Actuator Control (TAC) Module Internal Circuit
* P1531 A/C Low Side Temperature Sensor Fault
* P1532 A/C Evaporator Temp. Sens. Ckt. Low Voltage
* P1533 A/C Evaporator Temp. Sens. Ckt. High Voltage
* P1534 A/C High Side Temp. Sensor Low Voltage
* P1535 A/C High Side Temperature Sensor Circuit
* P1536 Engine Coolant Overtemperature - Air Conditioning (A/C) Disabled
* P1537 A/C Request Circuit Low Voltage
* P1538 A/C Request Circuit High Voltage
* P1539 A/C Clutch Status Circuit High Voltage
* P1540 Air Conditioning (A/C) Refrigerant Overpressure - Air Conditioning (A/C) Disabled
* P1541 A/C High Side Over Temperature
* P1542 A/C System High Pressure High Temperature
* P1543 A/C System Performance
* P1544 A/C Refrigerant Condition Very Low
* P1545 Air Conditioning (A/C) Clutch Relay Control Circuit
* P1546 A/C Clutch Status Circuit Low Voltage
* P1547 A/C System Performance Degraded
* P1548 A/C Recirculation Circuit
* P1551 Throttle Valve Rest Position Not Reached During Learn
* P1554 Cruise Control Feedback Circuit
* P1555 Electronic Variable Orifice Output
* P1558 Cruise Control Servo Indicates Low
* P1559 Cruise Control Power Management Mode
* P1560 Transaxle Not in Drive - Cruise Control Disabled
* P1561 Cruise Vent Solenoid
* P1562 Cruise Vacuum Solenoid
* P1563 Cruise Vehicle Speed/Set Speed Difference Too High
* P1564 Vehicle Acceleration Too High - Cruise Control Disabled
MADDOG
MADDOG
* P1565 Cruise Servo Position Sensor
* P1566 Engine RPM Too High - Cruise Control Disabled
* P1567 Active Banking Control Active - Cruise Control Disabled
* P1568 Cruise Servo Stroke Greater than Commanded in Cruise
* P1569 Cruise Servo Stroke High While not in Cruise
* P1570 Traction Control Active - Cruise Control Disabled
* P1571 Traction Control Torque Request Circuit
* P1572 ASR Active Circuit Low Too Long
* P1573 PCM/EBTCM Serial Data Circuit
* P1574 Stoplamp Switch Circuit
* P1575 Extended Travel Brake Switch Circuit
* P1576 BBV Sensor Ckt. High Voltage
* P1577 BBV Sensor Ckt. Low Voltage
* P1578 BBV Sensor Ckt. Low Vacuum
* P1579 P/N to D/R at High Throttle Angle - Power Reduction Mode Active
* P1580 Cruise Move Circuit Low Voltage
* P1581 Cruise Move Circuit High Voltage
* P1582 Cruise Direction Circuit Low Voltage
* P1583 Cruise Direction CircuitHigh Voltage
* P1584 Cruise Control Disabled
* P1585 Cruise Control Inhibit Output Circuit
* P1586 Cruise Control Brake Switch 2 Circuit
* P1587 Cruise Control Clutch Control Circuit Low
* P1588 Cruise Control Clutch Control Circuit High
* P1599 Engine Stall or Near Stall Detected
* P1600 TCM Internal Watchdog Operation
* P1601 Serial Comm. Problem With Device 1
* P1602 Knock Sensor (KS) Module Performance
* P1603 Loss of SDM Serial Data
* P1604 Loss of IPC Serial Data
* P1605 Loss of HVAC Serial Data
* P1606 Serial Communication Problem With Device 6
* P1607 Serial Communication Problem With Device 7
* P1608 Serial Communication Problem With Device 8
* P1609 Loss Of TCS Serial Data
* P1610 Loss of PZM Serial Data
* P1611 Loss of CVRTD Serial Data
* P1612 Loss of IPM Serial Data
* P1613 Loss of DIM Serial Data
* P1614 Loss of RIM Serial Data
* P1615 Loss of VTD Serial Data
* P1617 Engine Oil Level Switch Circuit
* P1619 Engine Oil Life Monitor Reset Circuit
* P1620 Low Coolant Circuit
* P1621 Control Module Long Term Memory Performance
* P1622 Cylinder Select
* P1623 Transmission Temp Pull-Up Resistor
* P1624 Customer Snapshot Requested - Data Available
* P1625 TCM System Reset
* P1626 Theft Deterrent Fuel Enable Signal Not Received
* P1627 A/D Performance
* P1628 ECT Pull-Up Resistor
* P1629 Theft Deterrent System - Cranking Signal
* P1630 Theft Deterrent Learn Mode Active
* P1631 Theft Deterrent Start Enable Signal Not Correct
* P1632 Theft Deterrent Fuel Disable Signal Received
* P1633 Ignition 0 Switch Circuit
* P1634 Ignition 1 Switch Circuit
* P1635 5 Volt Reference Circuit
* P1636 PCM Stack Overrun
* P1637 Generator L-Terminal Circuit
* P1638 Generator F-Terminal Circuit
* P1639 5 Volt Reference 2 Circuit
* P1640 Driver-1-Input High Voltage
* P1641 Malfunction Indicator Lamp (MIL) Control Circuit
* P1642 Vehicle Speed Output Circuit
* P1643 Engine Speed Output Circuit
* P1644 Traction Control Delivered Torque Output Circuit
* P1645 Evaporative Emission (EVAP) Vent Solenoid Contol Circuit
* P1646 Erative Emission (EVAP) Vent Solenoid Control Circuit
* P1647 Driver 1 Line 7
* P1650 Control Module Output B Circuit
* P1651 Fan 1 Relay Control Circuit
* P1652 Powertrain Induced Chassis Pitch Output Circuit
* P1653 Oil Level Lamp Control Circuit
* P1654 Cruise Control Inhibit Output Circuit
* P1655 EVAP Purge Solenoid Control Circuit
* P1656 Driver 2 Line 6
* P1657 1-4 Upshift Solenoid Control Circuit
* P1658 Starter Enable Relay Control Circuit
* P1660 Cooling Fan Control Circuits
* P1661 MIL Control Circuit
* P1662 Cruise Lamp Control Circuit
* P1663 Oil Life Lamp Control Circuit
* P1664 1-4 Upshift Lamp Control Circuit
* P1665 Driver 3 Line 5
* P1666 Driver 3 Line 6
* P1667 Reverse Inhibit Solenoid Control Circuit
* P1669 ABS Unit Expected
* P1670 Driver 4
* P1671 Driver 4 Line 1
* P1672 Low Engine Oil Level Lamp Control Circuit
* P1673 Engine Hot Lamp Control Circuit
* P1674 Tachometer Control Circuit
* P1675 EVAP Vent Solenoid Control Circuit
* P1676 Driver 4 Line 6
* P1677 Driver 4 Line 7
* P1680 Driver 5
* P1681 Driver 5 Line 1
* P1682 Driver 5 Line 2
* P1683 Driver 5 Line 3
* P1684 Driver 5 Line 4
* P1685 Invalid key recieved from the SmartKey immobilizer module (the thingie in the ignition that makes sure you are using a correct key)
* P1686 Driver 5 Line 6
* P1687 Driver 5 Line 7
* P1689 Delivered Torque Circuit Fault
* P1690 ECM Loop Overrun
* P1691 Coolant Gage Circuit Low Voltage
* P1692 Coolant Gage Circuit High Voltage
* P1693 Tachometer Circuit Low Voltage
* P1694 Tachometer Circuit High Voltage
* P1695 Remote Keyless Entry Circuit Low
* P1696 Remote Keyless Entry Voltage High
* P1700 Transmission Control Module (TCM) Requested MIL Illumination
* P1701 Trans. MIL Request Circuit
* P1705 P/N Signal Output Circuit
* P1740 Torque Reduction Signal Circuit: Overdrive and TCC Solenoid Rationality
o Al Steier wrote that P1740 is a Chrysler-only code, so the description is not always SAE approved. On RE transmissions, which don’t have much in the way of electronics, the computer was looking for a drop in engine speed after the overdrive solenoid or torque converter clutch were applied; since lockup comes in fourth gear, it doesn’t know whether the rpm drop is due to moving to overdrive or locking the torque converter. If a truck shows P1740 is probably has one of two problems: a bad overdrive or torque converter solenoid, or bad torque converter material so that the torque converter clutch cannot hold lockup.
* P1743 TP Signal from ECM
* P1760 TCM Supply Voltage Interrupted
* P1779 Engine Torque Delivered to TCM Signal
* P1780 Park/Neutral Position [PNP] Switch Circuit
* P1781 Engine Torque Signal Circuit
* P1790 Transmission Control Module Checksum
* P1791 Transmission Control Module Loop
* P1791 Throttle/Pedal Position Signal (2000+)
* P1792 Transmission Control Module Reprogrammable Memory
* P1792 ECM to TCM Engine Coolant Signal
* P1793 Transmission Control Module Stack Overrun
* P1793 Wheel Speed Signal (2000+)
* P1795 CAN Bus - Throttle Body Position
* P1800 TCM Power Relay Control Circuit
* P1801 Performance Selector Switch Failure
* P1804 Ground Control Relay
* P1810 TFP Valve Position Switch Circuit
* P1811 Maximum Adapt and Long Shift
* P1812 Transmission Over Temperature Condition
* P1813 Torque Control
* P1814 Torque Converter Overstressed
* P1815 Transmission Range Switch - Start In Wrong Range
* P1816 TFP Valve Position Sw. - Park/Neu. With Drive Ratio
* P1817 TFP Valve Position Sw. - Reverse With Drive Ratio
* P1818 TFP Valve Position Sw. - Drive Without Drive Ratio
* P1819 Internal Mode Switch - No Start\Wrong Range
* P1820 Internal Mode Switch Circuit A Low
* P1822 Internal Mode Switch Circuit B High
* P1823 Internal Mode Switch Circuit P Low
* P1825 Internal Mode Switch - Invalid Range
* P1826 Internal Mode Switch Circuit C - High
* P1831 Pressure Control (PC) Solenoid Power Circuit - Low Voltage
* P1832 Pressure Control (PC)/Shift Lock Solenoid Control Circuit High Voltage
* P1833 A/T Solenoids Power Circuit - Low Voltage
* P1834 Torque Converter Clutch (TCC)/Shift Solenoid (SS) Control Circuit High Voltage
* P1835 Kick-Down Switch Circuit
* P1836 Kick-Down Switch Failed Open
* P1837 Kick-Down Switch Failed Short
* P1842 1-2 Shift Solenoid Circuit Low Voltage
* P1843 1-2 Shift Solenoid Circuit High Voltage
* P1844 Torque Reduction Signal Circuit Desired By TCM
* P1845 2-3 Shift Solenoid Circuit Low Voltage
* P1847 2-3 Shift Solenoid Circuit High Voltage
* P1850 Brake Band Apply Solenoid Circuit
* P1851 Brake Band Apply Solenoid Performance
* P1852 Brake Band Apply SolenoidLow Voltage
* P1853 Brake Band Apply Solenoid High Voltage
* P1860 TCC PWM Solenoid Circuit Electrical
* P1864 Torque Converter Clutch Circuit
* P1865 4-5 Shift Solenoid (SS) Valve Control Circuit High Voltage
* P1866 Torque Converter Clutch (TCC) Pulse Width Modulation (PWM) Solenoid Control Circuit Low Voltage
* P1867 Torque Converter Clutch (TCC) Pulse Width Modulation (PWM) Solenoid Control Circuit High Voltage
* P1868 Transmission Fluid Life
* P1870 Transmission Component Slipping
* P1871 Undefined Gear Ratio
* P1873 TCC Stator Temp. Switch Circuit Low
* P1874 TCC Stator Temp. Switch Circuit High
MADDOG
MADDOG
* P1875 4WD Low Switch Circuit Electrical
* P1884 TCC Enable/Shift Light Circuit
* P1886 Shift Timing Solenoid
* P1887 TCC Release Switch Circuit
* P1890 ECM Data Input Circuit
* P1890 Throttle Position Signal Input
* P1891 Throttle Position Sensor PWM Signal Low
* P1892 Throttle Position Sensor PWM Signal High
* P1893 Engine Torque Signal Low Voltage
* P1894 Engine Torque Signal High Voltage
* P1895 TCM to ECM Torque Reduction Circuit
* P2008 Intake Manifold Runner Control (IMRC) Solenoid Control Circuit
* P2009 Intake Manifold Runner Control (IMRC) Solenoid Control Circuit Low Voltage
* P2010 Intake Manifold Runner Control (IMRC) Solenoid Control Circuit High Voltage
* P2066 Fuel Level Sensor 2 Performance
* P2067 Fuel Level Sensor 2 Circuit Low Voltage
* P2068 Fuel Level Sensor 2 Circuit High Voltage
* P2096 or P2098 Post Catalyst Fuel Trim System Low Limit
* P2097 or P2099 Post Catalyst Fuel Trim System High Limit
* P2100 Throttle Actuator Control (TAC) Motor Control Circuit
* P2101 Control Module Throttle Actuator Position Performance
* P2105 Throttle Actuator Control (TAC) System - Forced Engine Shutdown
* P2107 Throttle Actuator Control (TAC) Module Internal Circuit
* P2119 Throttle Closed Position Performance
* P2122 Accelerator Pedal Position (APP) Sensor 1 Circuit Low Voltage
* P2123 Accelerator Pedal Position (APP) Sensor 1 Circuit High Voltage
* P2127 Accelerator Pedal Position (APP) Sensor 2 Circuit Low Voltage
* P2128 Accelerator Pedal Position (APP) Sensor 2 Circuit High Voltage
* P2135 Throttle Position (TP) Sensor 1-2 Correlation
* P2138 Accelerator Pedal Position (APP) Sensor 1-2 Correlation
* P2176 Minimum Throttle Position Not Learned
* P2500 Generator L-Terminal Circuit Low Voltage
* P2501 Generator L-Terminal Circuit High Voltage
__________________
Status
Goodie1990
