after market clutch noise
jgoodwin
i have been researching after market clutchs, and people are saying they make noise at lower RPM. why is it making this noise and is it a bad thing?
Cummins Powered
Texas
2008 Ram 2500 4x4 3.73 gears,1994 Ram 2500 4x4 12 valve modified, Industrial Injection #5 fuel plate
6.7 Cummins, 5.9 Cummins
If you have a tuner it can cause the slippage issues. I'm sure you have checked out the Valair and South bend clutch?
J
jgoodwin
i have not bought a truck yet. im just making plans and doing research for when I get home from my deployment. I plan on getting the EFI live autocal, there for I wanna get a clutch too. I have looked at both brands and have read that after market clutches make noise when driving in low RPM's. I was just wondering why they make noise and if its a bad thing?
DannyMK2
Long Island, NY
2015 Power Wagon
did you even read the question?
its fairly common to get a rattling sound usually because people are stepping up to a dual disk clutch. they are noisier by nature. sprung hub dual disks are a little quieter than solid. the noise is usually at idle with the clutch out.
Goodie1990
