Ram 1500 EcoDiesel Block Heater Cord
Geno's Garage
*******, GA
Cummins Diesel
RAM 1500 ECODIESEL BLOCK HEATER CABLE
For all of you Ram 1500 EcoDiesel owners here, the 3.0-liter V6 diesel engine has a block heater installed, but many times the dealer did not order the engine block heater cable with the trucks. If your truck is missing this obvious 3-prong/110 volt AC cable (it should be on the passenger side of the engine underneath the exhaust manifold), let us help you correct the oversight.
OEM Block Heater Cable
Our Geno's Garage block heater cable is an affordable alternative to the expensive Mopar OEM block heater cable (PN# 68223420AB for $103) and it is easier to install in the tight confines of the engine compartment.
Geno's Garage Block Heater Cable
Our instructions below show you some tricks we learned to simplify the process of installing the block heater cable in your truck.
Ram 1500 Eco Block Heater Cable Installation Instructions
