Stock 2016 Ram 1500 5.7 Towing question
bri6679
Me and the family were thinking about renting a camper trailer for a long weekend I believe it said it was rated at 5000 pounds can I comfortably tow this without adding any sway bars for other stiffeners? The truck is equipped with the 3.21 axle ratio,class IV receiver hitch and Brake Controller switch
Sent from my SM-N915T using Tapatalk
coldfusion73
Ontario, Canada
Depends what the tongue weight of the trailer is. You might get some sag in the rear if it's too heavy
14hemiexpress
Texas
6.4l
You probably get away with it sense the owners manual states 6k is the limit at needing WDH but depending on how far you tow you may want to consider it not for weight but stability with the fact campers are pretty much a sail they are big light and solid sidewalls. If your going 20 miles to the local lake no biggie just be smart going 500 miles cross country I would look into seeing if you can rent a WDH.
bri6679
bri6679
Okay thanks for the information I'll probably be driving it no more than a hundred fifty miles each way
bri6679
bri6679
Not planning on doing it till like September so I have time to research thank you
PippinAin'tEasy
X2 Jerry's post. Won't be the best but it'll be better than nothing. 25' (guessing) is a good size sail for a newcomer. May want to rent a box trailer or 2 over the summer and donate yer time pulling 'em around to a local charity. Furniture pickups are the best.Practice with a purpose and whatnot.
"Oh, sweet debt. Thy name is Truck."
Dr.Lou
5.7 L hemi
Is the trailer 5,000# empty or loaded? Doesn't take much to get up to 6,000# + with water, food and other supplies.
twodips
2019 Classic
HEMI 5.7
You should be ok for such a short trip as long as you load things correctly (balance) and don't drive like a crazy person.
pcschwenke
Our truck is similar. We are towing a trailer on a weekly basis that weighs 6744lbs dry. It toes extremely well. I would use some sort of weight distribution hitch.
Riccochet
Somewhere around Charlotte
2020 2500 Laramie Longhorn
12% of 5000# is 600# tongue weight. And that 5000# trailer weight is dry weight. Add the battery, propane, gear and you are closer to, if not more than, 6000# of trailer weight. Now you are up to 720# of tongue weight. You should be fine on payload, but I'd seriously look at a WDH. Unless you like white knuckles and putting your family at risk.
It's usually smooth sailing, until that 18 wheeler passes you doing 70+ MPH. A WDH with sway control makes life easier. Especially if you aren't accustomed to towing a long, heavy sail.
