- Sep 3, 2012
- 1,060
- 78
- 2012
- hemi 5.7
AirLift 1000 60818 units are now shipping!!! Get yours now AirLift 1000
Part number60812
Price $88.62
The AirLift 1000 is an adjustable air helper spring engineered for coil spring suspensions, front or rear. Custom tune the ride you want, whether you’re hauling, towing, or riding light!
Leveling Capacity (LB): 1000 Pounds
Pressure Range (PSI): 5 To 100 Pounds Per Square Inch
Material: Polyurethane
Features
Up To 1000 Pounds Of Leveling Capacity
Air Adjustable Typical Maximum Pressure Is 35 PSI On Cars And Sport Utilities, 90 PSI For Motor Homes
Tough Molded Polyurethane Construction
Quick Connecting. No Mileage Restriction
Easy To Install With Illustrated Instruction Manual
Easy-To-Use Air Fittings
Easy To Install Using Common Mechanic Tools
Limited Lifetime Warranty
Product Applications
2009-2010 Dodge Ram 1500
2009 Dodge Ram 1500
•Position: Rear
•No Frame Drilling Required
2010 Dodge Ram 1500
•Position: Rear
2011-2012 Ram 1500
2011 Ram 1500
•Position: Rear
2012 Ram 1500
•Position: Rear
Thanks
Jeremiah
Discount Auto Performance
Part number60812
Price $88.62
Features
2009 Dodge Ram 1500
•Position: Rear
2010 Dodge Ram 1500
•Position: Rear
2011-2012 Ram 1500
2011 Ram 1500
•Position: Rear
2012 Ram 1500
•Position: Rear
Thanks
Jeremiah
