Clutch Fork Slipped ... Help
richml3
I pressed in the clutch pedal and felt something disengage. I had no clutch but I stayed in 2nd gear to limp home. I removed the inspection cover and noticed the clutch fork had slipped off the throw out bearing. I don't have a lot of experience with the Dodge assembly. The bearing has those little clips on the side. I'm hoping I can "just" reach up there and put this back together(?).
Does anybody have a diagram or photo of how this is supposed to go back together?
Is this something I can fix without any major disassembly?
I need help. Thanks!
