Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 1st Gen : 1981 - 1993 > General Discussions
General Discussions
Needing help
This is a discussion on Needing help within the General Discussions forums, part of the 1st Gen : 1981 - 1993 category!
I recently purchased a 91 W150 5.2 auto with a 241D transfer case. I am trying to understand why the ...
Reply
Old 01-18-2017, 07:44 PM   #1 (permalink)
Ram Year: 1991
Engine: 5.2
Default Needing help
I recently purchased a 91 W150 5.2 auto with a 241D transfer case. I am trying to understand why the vehicle has to be in motion before the front drive shaft will engage. It has mile marker hubs, I am use to shifting to 4H and go. I got stuck a few weeks ago and the only way to get out was to jack the front end up in neutral and rotate the front axle by hand until I heard the transfer case engage the front drive shaft. As long as you are moving forward or reverse it will engage every time.
Sponsored Ad
Register to remove this ad.
sajrgs13 is offline   Reply With Quote
Old 01-18-2017, 08:06 PM   #2 (permalink)
crazzywolfie's Avatar
Ram Year: 81 93
Engine: 5.2
Default
i don't know about your 91 but my 89 has shift on the fly. i can pull back the shifter easily whether in gear moving or sitting still.
__________________
81 dodge d150 custom long box 318 670CFM Holley Street Avenger Carb
89 RamCharger 4x4 318/727/3.21 on 33's
93 ramcharger 318 FI 2wd
crazzywolfie is online now   Reply With Quote
Old 01-21-2017, 10:08 AM   #3 (permalink)
Ram Year: 1991
Engine: 5.2
Default Thanks
My 91 also has shift on the fly. The problem is if you are parked for the day either hunting or fishing and try to leave and you are stuck. When you pull the shifter to 4H nothing happens, the front drive shaft doesn't engage unless the vehicle is moving. To me this makes a 4X4 useless.
Old 01-21-2017, 10:20 AM   #4 (permalink)
Ram Year: 81 93
Engine: 5.2
Default
ok so it sounds like the actuator for activating the axle shaft might not be pulling the sleeve over or having difficulties doing so. you might want to check to see if there is any vacuum leaks. this is not a dana 44 like on your truck but it should be similar in how the axle engages.
__________________
Old 01-24-2017, 09:34 AM   #5 (permalink)
Ram Year: 1991
Engine: 5.2
Default
Thanks. I have mile marker manual hubs, and the cad is locked. The front drive shaft does not engage (turn) until vehicle is in motion. Once in motion then you hear, and feel the front drive shaft engage. I thought when you placed in 4H or 4L the front drive shaft would automatically be engaged.
Old 01-24-2017, 12:44 PM   #6 (permalink)
Ram Year: 81 93
Engine: 5.2
Default
the transfer case should engage no matter what when you shift it. there should be no reason for it to not especially if you are stuck and not getting traction. all you should need to do is throw it in 4x4 jump out lock the hubs and then go
__________________
Old 01-24-2017, 05:15 PM   #7 (permalink)
Ram Year: 1991
Engine: 5.2
Default
I wish it did work that way. Any ideas on what could be the problem
Old 01-24-2017, 05:17 PM   #8 (permalink)
Ram Year: 81 93
Engine: 5.2
Default
maybe the transfer case needs an oil change. there is no reason it should not just engage when shifted into 4x4.
__________________
Old 02-03-2017, 09:40 PM   #9 (permalink)
Sniper X's Avatar
Ram Year: 1991
Engine: 318
Default
My 1991 is a manual but will engage when I pull the lever right away, like the second be I begin any forward motion
__________________
Resistance is not futile, it is voltage divided by current.
Sniper X is offline   Reply With Quote
Reply
Tags
241d, 4x4, transfer case
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Needing help Girritt Engine & Performance 4 10-01-2016 10:48 AM
needing help VFDPrim Engine & Performance 16 03-19-2015 01:37 AM
Needing some help bludolphan Engine & Performance 4 11-17-2014 01:24 PM
Needing a little help tommyboi87 Interior 4 08-30-2014 01:10 AM
Needing some suggestions badblackram06 Audio & Electronics 4 11-22-2010 10:37 AM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
