Lowering questions with D100
1stgen
Listowel, Ontario
Hello all, so I have an 88 D100 I want to lower, I've been looking around the internet some time now doing my research and it seems the common route is flipping the rear axle to get the ass down low which is mainly what I want done, pretty happy with the front as it sits for now anyways.
I found this axle flip kit but I've also read an axle flip as a way to lift a vehicle? How would I know if this is a lift or drop? They have provided this image:
And they list it as for a D150 which was my other question, would it bolt onto a D100 or require modification of some sort? (assuming its even what I need)
Few more things, I'm not 100% sure it would get too low in the back and be lower than the front, whats an effective way to lower the front? Cost is not so much an issue more than lack of skill here to build things lol, thanks! Picture or two of the rig: nN2h3Ps.jpg
1stgen
1stgen
Listowel, Ontario
Bump, anybody have any ideas? Or is this not the correct spot to ask?
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
Axle flips go both ways. You would lower the truck by making the axle sit on top of the springs.
That is good for about 2-4 inches I believe.
For the front you can get a set of Dodge B-series van lower control arms and net about 2 inches. More than that and you'll need lowering coils.
1stgen
1stgen
Listowel, Ontario
Thanks for the reply, that reaffirms some things I had been wondering actually. More or less thats all I need from dropping it nothing too radical just a bit of a better stance. Few more questions, is there a specific year or whatnot of said van that the LCAs need to be off of? And this was the kit I found specifically the actual page: 1974 1993 Dodge D150 RAM Charger 6" Rear Flip KIT | eBay it says 6" now I'm not 100% if thats going to require new shocks and some other **** or not, thoughts? Again thank you very much for the input its greatly appreciated!
1stgen
1stgen
Listowel, Ontario
Will i need new shocks for the rear? Sorry to double post just buying parts online and getting it all sorted i would assume they would have less room to travel and perhaps bottom out?
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
To my knowledge anything lower than 2" will require drop shocks. I do not know what good brands are as I am not a lowered guy.
Van LCAs were the same from 72-90 for sure. I think the later vans used the same frame as the older ones.
Wesd100
Texas
Has anyone tried these Drop Spindles from X2industries?
wondering about quality?
1978-1993 Dodge Ram, Charger, Trailduster 2" Drop Spindles
[DG7893DRM2]
Your Price: $373.95
www.x2industries.com
1-800-823-0320
instructions:
-NEED TO USE 84 ROTORS(PART #5315) TO MAINTAIN 5450 BOLT PATTERN
-FLIP TIE RODS
-REQUIRES LARGER INNER BEARING ON 83 AND DOWN CODE11
-REVERSE TAP OF Ball Joint FOR MORE CLEARANCE
Wesd100
Texas
on second look I think they are the same ones from airbagit.com
Midnight 4x4
Houston Texas
2014 and 1984
5.7 and a slant six
7337D013-353E-4879-8077-63306B94469D.jpeg On rockauto b250 lower control arms are less than $40. This is all the mods I had to do to them. The mount on the truck needs to be drilled out to 3/4in for van LCA
Wesd100
Texas
Which mounts are you referring to, midnight?, I thought the van la bolted right up?
Midnight 4x4
Houston Texas
2014 and 1984
5.7 and a slant six
I meant the truck lower control arm mount has to be drilled out to 3/4 in an trim around the van arm that goes in truck mount
Wesd100
Texas
has anyone used the: " SHA-DO7893 Shackle Drop/Zerks Old Ram "
from airbagit.com?
is there any modification needed like for the chevy drop shackles? I've got a 86 d100
1homeblown
Torrance
DodgeAddict,
Resurrecting this thread a bit for a truck I just brought home. Can you tell me what drop (front and rear) you did with the truck in the picture?
Thanks!
Jems007
