Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 1st Gen : 1981 - 1993 > Engine & Performance
Trans and rear end swap
This is a discussion on Trans and rear end swap within the Engine & Performance forums, part of the 1st Gen : 1981 - 1993 category!
So I have an 88 D150 I've decided to worry more about gearing than power for now, eventually truck will ...
Sponsored By: Moe's Performance
Reply
Old 01-11-2017, 07:30 PM   #1 (permalink)
Ram Year: 1988
Engine: 5.2
Default Trans and rear end swap
So I have an 88 D150 I've decided to worry more about gearing than power for now, eventually truck will have a 360 in it I'm wanting 300whp and 375ft-lbs, just curious what would be a good transmission for that and one that will still be fine with my current 318, I'm thinking about pulling the rear end out of a newer ram as well for disk brakes
Sent from my Coolpad 3622A using Tapatalk
Sponsored Ad
Register to remove this ad.
dev199505 is offline   Reply With Quote
Old 01-11-2017, 08:44 PM   #2 (permalink)
crazzywolfie's Avatar
Ram Year: 81 93
Engine: 5.2
Default
i don't know if the rear end out of a newer truck will bolt in. i think you need to move the leaf spring perches and get new rims since the newer axles are wider.
do you know what transmission you currently got? if money is not an issue and you are going to use it as a cruiser/toy then i would go with a 46RH. if it is just going to be a toy i would go with a 36RH(727). they are pretty much the same transmission except 1 has overdrive which makes them a bit more expensive than the one without overdrive.
__________________
81 dodge d150 custom long box 318 670CFM Holley Street Avenger Carb
89 RamCharger 4x4 318/727/3.21 on 33's
93 ramcharger 318 FI 2wd
crazzywolfie is online now   Reply With Quote
Old 01-11-2017, 09:10 PM   #3 (permalink)
Ram Year: 1988
Engine: 5.2
Default
Pretty sure it's the 727 3 speed automatic, I was wanting of to help with gas a little bit, but the truck is definitely geared for highway, seems to get awesome mileage on the highway way (got 400miles to the tank) so was thinking with OD it would be even better especially in town
Old 01-11-2017, 09:12 PM   #4 (permalink)
Ram Year: 1988
Engine: 5.2
Default
I was also wanting to get 20's off a newer dodge ran but wasn't sure if they would fit on my truck since the center bore seems bigger on mine truck is going to be a cruiser/show truck
Old 01-11-2017, 09:34 PM   #5 (permalink)
Ram Year: 81 93
Engine: 5.2
Default
around town the fuel mileage would be about the same between the 727 and 46RH since they are pretty much the same. the 46RH would do a lot better on the highway than the 727 would tho. my 93 would do about 14-16 mpg on the regular basis where my 81 would get about 10-12mpg doing the same driving. if i slowed down my 81 might have been able to get the same average mileage as my 93 but then again if i drove my 93 at those same speed i could probably get 18mpg.
a 727 would do just fine for the 360 tho.
the hubs on the front are larger. i think you would need spacers to make them work but not 100% sure on that
__________________
Old 01-24-2017, 08:18 PM   #6 (permalink)
Ram Year: 1988
Engine: 5.2
Default
I think I actually have the 904 trans
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Trans Swap? TheEverythingApprentice Engine & Performance 0 06-07-2016 01:00 AM
Trans Swap Misfit Ram Engine & Performance 17 08-10-2015 07:28 PM
trans swap? Slamminwagon General Discussions 1 12-22-2014 10:30 PM
5.7 Trans swap 05Ram1500_5.7hemi Tech Info 4 12-18-2014 09:22 PM
Trans swap Ram_sport_5.2 General Discussion 1 04-09-2014 12:40 AM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
