Rear End Swap
Smokey196240
Preston,Mo
2001 ram 1500 & 2006 Ram 3500
2001 5.9 , 2006 5.9 Cummins
What I have is a 2001 2WD dodge ram 1500 w/318 auto can get a 2003 rear end out of a 1500 5.7 truck 2wd will thay swap ? and what do i need to do to make it work. thanks for any and all help.
GTyankee
El Cajon Calif. 92021
3.0 ecodiesel
2001 Dodge Ram 1500 & a 2003 Dodge Ram 1500 have different body styles.
Both differentials are 9.25" AAM Differentials
both should have flat springs & shackles.
There is a good chance that they will interchange, just break out your tape measure
Are both differentials off a 2 wheel drive pickup ?
Heavy Duty Dodge Rams, like your 2006, use a larger differential & would not work
18CrewDually
U.S.- New Jersey
Cummins 6.7 H.O.
If I'm not mistaken, 2001 is drum brake. 2003 is disk brake. So you will need to swap the parking brake cables and the Proportioning Valve near the master cylinder.
I just swapped a 2004 Ford 8.8 disk rear into a 1994 Dakota that was drum. The proportioning valve for the drum rears keeps too much residual pressure on the disk setup so it keeps the brake pressure applied to a point it will overheat the pads. I swapped out the residual pressure spring for a lighter one and it works perfectly now.
For anyone else I'd recommend to just grab the lines and proportioning valve from the donor truck and swap it.
Joey93
