Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 1st Gen : 1981 - 1993 > 1st Gen DIY
1st Gen DIY
How to get that 1st Gen down low
This is a discussion on How to get that 1st Gen down low within the 1st Gen DIY forums, part of the 1st Gen : 1981 - 1993 category!
To lower your 1st gen you can use a lot of stock Dodge parts & aftermarket Chevy stuff as well ...
Like Tree7Likes
Reply
Old 01-31-2012, 12:22 AM   #1 (permalink)
Ram Year: 1984 1985 1977
Engine: 5.9 Magnum
Default How to get that 1st Gen down low
To lower your 1st gen you can use a lot of stock Dodge parts & aftermarket Chevy stuff as well a Mopar Performance pieces. How low is how much you want to spend or work or both. These mods will work only on 100-250 series with a 3300# front axle or 1/2 lugs
In the front you can use
72-94 Dodge Truck with 4000# front axle LCA's single wheel or dually 1 ton
8 lugs 9/16-5/8" 8 lugs 1/2" will not work
You press the balljoints intended for your truck in them
You have to drill your hangers on the frame to fit the pivot bolt hole in the LCA's bushing. 3/4"
If you use these you can use your factory sway bar
See the 1st pic
78-98? Dodge van B150-B350
5 or 8 lugs 1/2"
On these you have to cut the steering stop off
You have to drill the the strut rod holes
You have to grind the arm around the bushing to fit it in the hangers
You have to drill the hangers to fit the pivot hole in the bushing 3/4"
You press balljoints intended for your truck in them
If you order these LCA's off ebay the balljoints that come in them will work.
As of this time I've not taken the time to figure out how to use the factory sway bar on these yet
See the 2nd pic
On some trucks you will need offset problem solver bushings to align correctly
These simple mods are good for 2-3" depending on your springs
You have to cut the bump stop bracket off
You have to build a adjustable stop to keep your spring seated
See the 3rd pic
Sponsored Ad
Register to remove this ad.
LifetimeDodge is offline   Reply With Quote
Old 01-31-2012, 12:30 AM   #2 (permalink)
Engine: 5.9 Magnum
Default
In the front you can use a 1st Gen Dakota 2" drop spindle from BellTech to gain another 2"
You have to use a balljoint ream to ream the tie rod on the bottom side to fit the full size tie rod end & to move it from the top to the bottom These spindles are $310.00+shipping from Jeg's
You can use lowering springs for a 2nd Gen Ram also a 2" spring will get you an inch
I cut springs too but you have to watch doing this because you can go so low as to break or bend the balljoint studs
In the future I will do a thread showing how to drop 7" in the front using stock parts with the Dak spindles. My 85 is going to get really low using stock suspension & Dak steering rack
Old 01-31-2012, 01:13 AM   #3 (permalink)
Engine: 5.9 Magnum
Default
In the rear you can figure you have to drop an extra 2" VS the front due to the rake that the rear springs give the truck.
To get 4" in the rear to match the LCA's you can do it 2 different ways.
You can flip the front spring hanger over & use a 2" lowering shackle for a 88-98 Chevy truck
You have to trim the bed braces to clear the springs
The second way involves flipping the front hanger & moving the rear hanger up 2" drilling new holes & bolting them back on.
You have to trim the ears off the hangers they will hit the bed braces as the springs will hit too
You will want to take the bed off.
To get 5-7" in the rear you flip the axle on top of the springs
You can do this 2 ways
You can use a axle flip kit for a 73-98 Chevy truck & universal shock plates or C,B,or E with a 8 3/4 or 9 1/4" rear end
You have to grind the U brackets & weld them to the original perches
Or you can use weld on spring perches from Mopar Performance & the same shock plates as above
Old 01-31-2012, 01:23 AM   #4 (permalink)
Engine: 5.9 Magnum
Default
As with any mods like these, there are other things that need to change also.
If you do a axle flip you will need to move your parking brake lever & cable bracket up on the frame like in the pic This keeps it from dragging on anything
Orangeone likes this.
Old 01-31-2012, 01:29 AM   #5 (permalink)
Engine: 5.9 Magnum
Default
Here's my RC with a axle flip & a van LCA. The tires are 225 60 15 in the front & 255 70 15 for the rear. I staggered the tire size to make up for the lack of Dak spindle for now
Old 01-31-2012, 09:25 AM   #6 (permalink)
WhiteExpress's Avatar
Ram Year: 2014
Engine: 3.5 EcoBoost
Default
Swwet merciful crap that's low. I love it!
Redtruck-VA and usaf2006 like this.
__________________
2014 F150 SuperCrew EcoBoost 4x4
WhiteExpress is offline   Reply With Quote
Old 01-31-2012, 12:59 PM   #7 (permalink)
Engine: 5.9 Magnum
Default
Thank You! My shorty will be 2 1/2" lower than that when I'm done with it. I like my trucks either lowered or lifted
Old 02-16-2012, 02:35 PM   #8 (permalink)
Ram Year: 1983/93
Engine: 5.9 Cummins
Default
I'm running the LCA out of a 93 D250 cummins truck in mine. It's got drop hangers on the back and I plan on flipping the rear on top of the springs. My truck isn't your ordinary shortbed though.
Redtruck-VA likes this.
dazedandconfused is offline   Reply With Quote
Old 02-16-2012, 02:37 PM   #9 (permalink)
wermbang's Avatar
Ram Year: 2001 Off Road
Engine: 5.9L V8 Sport
Default
pretty neat , got any more pics?
welcome to the site
__________________
Superchips 3715;3rd gen 20s; Cat back exhaust, no muffler;Custom Grill Insert; SRT Hood; Hummer Nerf Bars (PD);Roll Bar (PD); Halo Projectors w/ 6K HIDs; Tow Mirrors; Body matched antennae base and handles; Custom tail Stripe; Custom decals; Painted frame, suspension parts, and wheel wells; Air Horn; Aluminum fuel door; one of kind dents and scratches; 2.5" TGC Leveling Kit; Bilstein 5100 Shocks; LED dash lights ;Cleared needles; blue switches; Painted dash pieces; Pioneer CD player; Cerwin Vega 6x9s , Alpine 5 1/4;Kenwood amp; RF sub w/Boss Amp; 5% window tint on the back, and strip on the front; trail grapplers
New Here? Introduce yourself here - Click here to become a Supporting Member - Check out our Preferred Vendors!
wermbang is offline   Reply With Quote
Old 02-17-2012, 02:23 AM   #10 (permalink)
Engine: 5.9 Magnum
Default
The LCA from that Cummins is a 4000# LCA Welcome Dazed! How fast is your oil burner?
Reply
Bookmarks
Tags
dropped 1st gen, lower 1st gen ram, lowering 1st gen
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
