Tinsey
I just serviced my rear diff so while it was on the jackstands I decided to run the rear wheels just to see how straight everything is running. New tires a week ago so I figured it should be perfect. NOPE. The right rear ain't bad but left rear runs out not only front to rear some but actually wobbles like a bent rim. Pulled off the "Mag" wheel and you can plainly see the rotor not concentric. I have the 11.5 diff and can't imagine the hub being bent. Actually can't imagine these big ass rotors being bent either but something is not running true. Anyone have this issue? I have searched the heavy duty section to no avail on rotors. A quick look around and can't even find new ones. Any recommendations?
Thanks
Thanks
