Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 4th Gen : 2009 - Present > Heavy Duty
Heavy Duty
Raced a 16 Silverado 2500hd-6.0...LOST
This is a discussion on Raced a 16 Silverado 2500hd-6.0...LOST within the Heavy Duty forums, part of the 4th Gen : 2009 - Present category!
It wasn't TFL that said the 8sp wasn't going in the HD. They relayed what Ram rep told them. It ...
Like Tree58Likes
Reply
Old 01-08-2017, 07:37 PM   #111 (permalink)
drittal's Avatar
Ram Year: 2013
Engine: 6.7
Default
It wasn't TFL that said the 8sp wasn't going in the HD. They relayed what Ram rep told them. It doesn't change the fact that there is a transmission used in HD trucks with better gear spread. I have to believe in both cases it is a financial decision not to use either. The Aisin just for the premium and the 90 because according to Ram it isn't up the the rigors of a HD without redesign of at least the parking prawl and subsequently the entire case
Sponsored Ad
Register to remove this ad.
drittal is offline   Reply With Quote
Old 01-08-2017, 08:34 PM   #112 (permalink)
drittal's Avatar
Ram Year: 2013
Engine: 6.7
Default Raced a 16 Silverado 2500hd-6.0...LOST
https://www.motor.com/newsletters/20...8HP_Tranny.pdf
So in 2012 Chrysler posts about the new 8sp including the 90 and put in print they won't replace HD transmissions. This is before the 6.4l even. Going on 5 yrs and still no use in the HD line even after developing the 6.4l and having to develop the gear hold programming because of the gear ratios of the 66rfe.
I have to wonder if the downfall of the ZF8 in the HD doesn't revolve around the electronic shift. We have all at one time or another had a vehicle on an incline and it clunked shifting out of park. Maybe the electronics are not strong enough to reliably shift out of park for vehicles at the weights of HD line, including the gas models.
Old 01-09-2017, 01:32 PM   #113 (permalink)
Ram Year: 2015
Engine: 6.4 Hemi
Default
Originally Posted by drittal View Post
Hell, the 66 is a 68 stuffed in a 545 case. Lol
If you go back and read what I wrote, I never said the 45RFE and 66/68RFE were the same, I said they were the same design,I was told this was ludicrous and silly.
I stand by that statement.
I think anyone who has both apart would agree with me
yoda is offline   Reply With Quote
Old 01-09-2017, 01:34 PM   #114 (permalink)
Ram Year: 2015
Engine: 6.4 Hemi
Default
Originally Posted by theviking View Post
Well, sort of. It appears to be a bit of a hybrid, at least according to Allpar articles. This is from another forum post some time back:
Doing some reading on the 68 vs 66 from another Allpar article.
The 68RFE and 66RFE automatic transmissions for Ram trucks
So, in comparing to the 68RFE it appears that 3rd and 5th would be the weakest link since the underdrive/overdrive and 4c clutches are not upgraded in the 66RFE. The low range and 2c clutches (1st and 2nd) are upgraded per the article. It's unclear (to me) if the 4c and UD/OD clutch assemblies from the 68 could be retrofitted into the 66RFE, but would seem like a logical place to start during a rebuild. Per Brandon, 4th would seem to be the best gear on the dyno since no clutches are engaged. I will have to follow up with HF to see what his actual concern is.
Not sure who Brandon is, but anytime the Engine is running there is a clutch applied
Old 01-09-2017, 02:21 PM   #115 (permalink)
Ram Year: 2015
Engine: Hemi 6.4
Default
I should have stated no holding clutch is applied per the chart. Basically what Brandon was stating is that this is the strongest configuration for a dyno pull. Obviously my overall understanding of an auto trans is limited. So out of curiosity, which clutches are engaged on the 66RFE when in 4th?
__________________
2015 Ram 2500 CCSB Laramie, 6.4, 4.10's, ARH LT Headers, MF Cat-back, HF 93 tune, Edge 2600 converter, Moe's 87mm TB, Traxda leveling kit, Thuren adj. track bar, Centerline Grizzly 20x8.5 rims, Cooper S/T Maxx 35's.
2012 Mustang GT, 1986 Mustang SVO, 2003 CBR 954, 2014 MDX
theviking is offline   Reply With Quote
Old 01-09-2017, 03:03 PM   #116 (permalink)
Ram Year: 2015
Engine: 6.4 Hemi
Default
OK understood. Makes sense, with no holding clutches applied, the power also goes straight through and doesn't use or put stress on any planetaries.
UD/OD, in 4th on the 66. same as the 68RFE in your chart above.
Old 01-09-2017, 05:41 PM   #117 (permalink)
drittal's Avatar
Ram Year: 2013
Engine: 6.7
Default
If you go back and read what I wrote I never quoted you as saying that. I could be wrong (probably) but from what I have read about the 66 is it is basically Ram taking the gears from the 68 and making them work in the 545 case but with 68 output shaft and extension housing. Thus my short statement of the 66 is basically a 68 stuffed in a 545 case. Sure, there are differences between the them, but the short answer is what I wrote.
Old 01-09-2017, 06:53 PM   #118 (permalink)
Ram Year: 2015
Engine: 6.4 Hemi
Smile
[QUOTE=drittal;1434047]If you go back and read what I wrote I never quoted you as saying that. I could be wrong (probably) but from what I have read about the 66 is it is basically Ram taking the gears from the 68 and making them work in the 545 case but with 68 output shaft and extension housing. Thus my short statement of the 66 is basically a 68 stuffed in a 545 case. Sure, there are differences between the them, but the short answer is what I wrote.
Sent from my iPhone using Tapatalk[/QUOTE
OK, I thought you were poking fun at me and South Texas conversation. Which also would be ok.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Sigh...lost a to girl with a 2015 Chevy Silverado 1500 gregshin Audio & Electronics 11 04-24-2015 08:47 AM
Raced a 3rd Gen Cummins MiRamDriver Engine & Performance 2 05-20-2014 01:29 AM
Just Raced Im Still Shocked!!! Adams2013 Engine & Performance 30 06-23-2013 10:46 PM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
