Rockk88
Hi, Just picked up a used 2500 Rocky Ridge Cummins, I believe it has a 6" pro comp lift on it but not sure if its an 8". Currently running 38's with -12 offset and zero rub unless off chamber turning. Has the cheaper white shocks which I assume are pro comp, as there is no branding on them.
I'd like to upgrade to a better shock, like a FOX or something along that line. Having a hard time finding an equivalent swap out shock. I've found ones for 2009 to 2013 but not 2014 and up. Would like to find a resi or dual setup for the front and a resi setup for the back.
