2nd gen fog lights
Status
Not open for further replies.
Hollabakzach23
Lafayette, IN
Hey everyone! So im looking for a decent looking set of the stock fog lights for my 98. My drivers one is decent but my passengers one has a hole in it and has collected water so i would like to find a little cheaper set in good shape so i dont have to spend at least 60 bucks on a new set via ebay special. If anyone has anything let me know!
I would also like to add that i am looking for some cab lights to install too if anyone has any for sale!
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
If you aren't able to find anything, let me know.
I can order a set on my next order from TYC - a set would run $55 shipped.
Hollabakzach23
Hollabakzach23
Lafayette, IN
Awesome ill keep ya posted for sure! Just didnt know if id be able to find anyone with a part out or anything first. But TYC is pretty popular around here so for good quality and 5 dollars cheaper ill keep it in mind!
ramhunter9
P-Star Jeep Wrangler
I had a old set but gave them to a member a few months back .. I would have givin them to ya . Sorry
WhiteExpress
Midland, TX
I had the projector versions, they worked awesome.
I had to modify the mounts, but they served me very well.
rambob
LA/MS
318 5.2l
do tell more.
edit. found them, for about $100
Hollabakzach23
Hollabakzach23
Lafayette, IN
Projectors? I saw some like that but i kinda want to keep the stock style housing like my headlights so when i put hids in them they will match.
WhiteExpress
Midland, TX
You can kind of make them out in this picture. It's the best picture I have of them, They had a really good cut off, I was always going to order HIDs for em and never did.
I often drove with those and parking lights only. Very good lights. I just had the lame 55W halogens in em they came with. Worked excellent!
Hollabakzach23
Hollabakzach23
Lafayette, IN
Does anyone know how big in diameter the fog lights are by chance? I found some that would mount up on my bumper but im not sure if they will fill the holes or be too much. The lights i found are 3 inches in diameter and clear lensed.
WhiteExpress
Midland, TX
You need a touch under 4". a 3" light would fit, but look kind of small.
Truthfully, it's kind of a pain to mount lights into these bumpers. The factory brackets are strange, mount infront / above the stock lights. Very strange setup.
Hollabakzach23
Hollabakzach23
Lafayette, IN
These would probably work then. I lied to you guys theyre 3.5 inch my bad! Ive never pulled the stock ones off and this may be a dumb question but is it possible to use the stock mount on a different set of lights so it will go back up in the stock location? I need to just get under there and pull em out just havent had the time yet!
WhiteExpress
Midland, TX
I have no idea. Mine didn't have stock lights when I bought it.
Yea, 3.5" would be the ideal size.
rambob
LA/MS
318 5.2l
it would be interesting. I dont think it'll be easy.
the best way would be sideways to that vertical part right by there.
Status
