12-20-2010, 06:59 PM
#4 (permalink)
Super Moderator
Location: Hometown : Puyallup,WA Stationed : Little Rock, AR
Name: Steven [TRIP/TRUP]
Ram Year: 2011 Ram 1500 4x4 Hemi Crew Cab Sport
Engine: 5.7L HEMI
1st option. You can go with springs for the front, but they will tweak your steering and handling geometry. Cheaper.
2nd option. You can go with spindles which will keep your oem steering and handling geometry, and improve it a lil. More expensive.
Either way you'll have to get a flip kit for the rear 4.5 drop. Basically flips the axle on top of the leaf springs, as opposed to under it, as it is now. Also, both ways you'll still want an alignment done after, and new shocks.
McGaughy's
McGaughy's- Air Bag Helper Kits
Ground Force
Ground Force Lowering Suspension Systems - Engineered From The Ground Up
DJM also has some drop lower control arms or something, but I'm not familiar with them. Hope this helps.
__________________
RamForum.com Moderator
