Lowering springs question
JT who
Grove, Okla
Question. Have 2005 1500. Would like to know. How much can i lower the front WITHOUT. having to change out a lot of parts. or going with a lowering kit. Looking at lowering it about 2".
CorDog009
East Texas
2” you won’t have to change anything besides the springs and shocks, and could probably get by without even doing shocks.
mikeynonos
IL
All I changed was the torsion bar adjusters and used Belltech Shocks. On the rear, I purchased the 3" lowering leaf springs and also Belltech Shocks. I may try to get the front a little lower (like 1/2"), but the rear sits fine for me and I can still use the bed.
g-nut
South Alabama
I lowered the front 4" with coils and control arms. The rear 6" with a Street Edge flip kit and shackles. Also changed the swaybar end links to shorter units (a Ford part)(K80337) Rides as well as it did before.
I replaced the 1 yr old Gabriel shocks with the entry level BellTech units. No difference in ride quality there.
I did ended up having to install a BellTech under bed frame notch because on pretty big bumps or hauling just a little weight in the bed the axle would hit the frame. Doesn't do it any more.
puma69
Riverside CA
Cut 1 or 1.5 off spring. 123 easy and it's free. Just put new ISO's and neo bushings if your uncertain but not needed.
Lowrider357
