2010 Dodge Ram 3500 Lone Star Edition
CumminsTxBoy89
Houston
6.7 Cummins I6
Well after a long long time of waiting, I have finally purchased my dream truck....we named her Dory, because she is blue it's an 2010 Dodge Ram 3500 Lone Star Edition with 6.7 Cummins has 98k and it's a crew cab. I have been very blessed to have the opportunity to purchase this truck and can't wait to use it!!! Getting ready to put her to work and tow our 5th wheel trailer.
Not much upgrades to really come other than a tuner probably sometime next year.
I was under the truck looking today and I saw 2 round pieces which look to be catalytic converters? Cause from what I can tell I DO NOT have DPF!! I will post more pictures later of interior etc but very amazing truck and love it already!!
Sent from my SM-G920T using Tapatalk
quietpeen
2021 TRX
Hellcat
Congrats. Is it 2wd or 4x4. From the pic I'm guessing 2wd
huntergreen
pretty sure you don't have DEF in your truck. you do have regen system in the exhaust, so avoid quick short trips. congrats and enjoy your travels.
CumminsTxBoy89
CumminsTxBoy89
Houston
6.7 Cummins I6
Okay is the regen system probably one of those 2 big cylinder looking things? Can I remove the regen system and not mess up my motor?
CumminsTxBoy89
CumminsTxBoy89
Houston
6.7 Cummins I6
Only asking cause right now I don't quite have the money to blow on a tuner that I can put I have these items deleted, so even if I can pull off the NOx and DPF and take out the filters and leave the connections plugged in to give it the impression it's still there?
CumminsTxBoy89
CumminsTxBoy89
Houston
6.7 Cummins I6
I did already do one upgrade and that was tinted the windows due to the fact that dodge has no tint on front windows from factory for whatever reason, next "upgrade" will be getting my fifth wheel hitch installed on it.
huntergreen
not really sure if you can just 'unplug" your region exhaust system. i tend to think that would clog up the system with soot. do you have to go through inspection? if yes, you can't do a delete kit. i have had 5.9 cummins, hopefully someone more familiar with 6.7 will jump in.
Csanders1992
Yeah you can't just unplug it. It'll likely put it into limp mode. You need a tuner to turn it off
