6.7 Diesel or 6.4 Hemi
Taylo1
Childress, Texas
Needing help! I am thinking I'm going to go to a HD, but I having a hard time deciding on which one will fit me better. I tow my jeep a couple times a year which is about 7500lbs with trailer and now I am probably buying a 4 seater utv which is about 1700lbs, so close to 9200lbs total and i tow about 1200 miles round trip up some pretty good grades. I also run a hunting ranch which during hunting season I haul alot of feed about 25 miles out.
Will also need to go with a 26 to 28' goose neck trailer which will be even heaver than my 20'.
smurfs_of_war
Swift Current, Saskatchewan
The cummins sounds like the animal for you. I have the 6.4L, love it for what it does, but you'd be way better served by the cummins- it's a great power plant purpose bred for what you are wanting to do.
On a side note- is your jeep on tank tracks or have bullet proof plating?
Sent from my SM-G925W8 using Tapatalk
7777xm
Covington, GA
Honest opinion, if it's just a few times a year, and HD probably isn't even necessary. But if you want to go to HD route, I'd go with gas. Diesel is a whole different beast and it could get real expensive real quick. Diesels are really nice to have and I still miss mine but unless you really need one and towing a lot with it, they're really not worth it unless you really just "want" one!
Sent from my SM-N920T using Tapatalk
drittal
E. Montana
Either one will do the job. The cummins will net you about 2mpg better depending on your driving style and will never lack power towing your rig. The 6.4 will be 6-8k cheaper for same options and will lose some speed going up steep hills and will downshift to remain in the power band 4-5k rpm when doing so. If towing over mountains you may also find the gear hold feature. To my knowledge I may be the only owner here to trigger it, but it happens. It is surprising at first, and can be annoying if you are the kind of person who hates going slow. I have only triggered it on grades of 7% or higher, never on interstate grades, with 11,000+ lb 36' toyhauler. But I'm almost at 100% of my GCWR. Go with 4.10 gears if you do get a 6.4l truck.
If you put on a lot of miles or tow in the mountains, cummins. Be prepared to buy a OBDII reader to clear codes if you get a weak batch of def.
Now, the Cummins will still downshift if you tow where I tow. But where the hemi needs 2nd, the Cummins is in 4th. However, interior noise level in a cummins dragging a trailer up a pass at 2,400rpm is very similar in volume to a 6.4l at 4,200.
Good luck with your choice!
Sent from my SM-N900V using Tapatalk
Taylo1
Taylo1
Childress, Texas
U&A
Michigan
2016 3500 SRW
6.4 HEMI
touchy subject, gas vs diesel....
JMO
the 6.4 will do it, no problem. the 6.7 will do it easier and cost you more money up front and throughout its life just because the "normal maintenance" things to do cost more. If your not sure if you NEED the 6.7 than it sounds like you are in the same boat I was.
I got the 6.4 and am happy with its performance. its all about what you want to pay for in the end.
JMO
U&A
Michigan
2016 3500 SRW
6.4 HEMI
just remember that each one will be better than the other in their own aspects.
TRCM
USN, Retired
Newport News, VA
2012 1500 Laramie CC 4x4
That's with the Trailer..... Made the correction, plus it was 1 a.m.
Whew.....gotcha........was gonna say, even if you had a full cage, heavy bumpers, 2 1/2 ton axles, 48" tires, it'd he hard to hit that number (unless it is a full size cherokee).
Was gonna ask for pics/specs......................
Galion
Edmonton, AB
For how much you say you'll be towing and hauling, the hemi will handle the loads and will cost less overall.
stoney
Ontario
2015 | 2500 SLT CC
6.4L w/ 4:10
Once ST chimes in, the pages will add up fast on this one :)
For the weight & frequency, 6.4 will do....but the terrain is where you may want to look into the 6.7.
Fun times, buying a new truck, especially an HD!
Reactions: U&A
U&A
Michigan
2016 3500 SRW
6.4 HEMI
now now Mr. stoney :Nonono:
LOL :roflsquared:
Taylo1
Taylo1
Childress, Texas
Yea, I'm not going to get in a big hurry. just gonna gather as much info as I can and see what I can find. I know the end of the year is coming up, so that may make some better deals come alive. Talking to a few guys around town that have the 6.7.
stoney
Ontario
2015 | 2500 SLT CC
6.4L w/ 4:10
LOL :roflsquared:
Kind of surprised I was the first to make that comment!
I think the 2016 model year is done....only what you find on a lot is what there will be, or order a 2017.
Taylo1
Taylo1
Childress, Texas
Yea, I wish they would put the 8sd in the 6.4 HD, that would everything better.
