8 speed auto park
talk2cpu
2014 1500 Bighorn Crew
Hemi 5.7, RamBox
Is there a way to temporarily disable the 8 speed from automatically going into park when the engine is shut off in neutral? Makes it real inconvenient when you are supposed to shut it off in the car wash. What about the carwash when an attendant puts it into the line? Could create an issue. Also if disabled and need to push it out of traffic.
Tom
jwheeler
Washington
There is an emergency release that can be pulled. Above the parking brake. Pop out the little panel.
Diller
Nashville TN
6.7 HO Cummins
Never been to a car wash that makes you turn it off. I have just been told to put it in neutral.
clh1220
st Louis
Ya I just go through the car wash with it in neutral and still running. I never shut it off. Using the by pass for taking it out of park is not a quick easy task. Just leave it running. Oh and have you seen how then ******** kids drive other people's vehicles. Don't let them drive yours.
PostalTwo
Edmonton
hemi
I never go thru auto car washes of that type. They scour the finish
john94si
WHERE? my 8speed tranny locked up one day and would not shift into any gear in a parking lot. I called RAM and they did not know how to override the switch to enter neutral to push the truck at all. I had to power it off for 15 min for the ECU to fully reset before i could move out of the way of traffic.
can you take a pic or where is it in the manual?
ExpressRules
Southern New Jersey
2014 Express Crew Cab & 2019 Big Horn Crew Cab
Well the ones I go through are brushless. So I think it will be ok.
Unless all they use are water wands it cant be truly "brushless". I've seen many car washes that claim to be brushless still have "cloth" type objects rubbing up against the body. To me that may meet the letter of the law but not the intent.
iam_canadian22
northern ontario
Our brushless or touchless wash spray on the soap and use a bunch of pressure washer nozzles for the cleaning, they work pretty good actually
Stangshcky12
Oshkosh, WI
5.9 Cummins
With the quality issues Ibe seen with the paint on these new trucks, I would be weary of the brushless ones even
clh1220
st Louis
The one I use is just water. No brushes or straps. And if your afraid your paint is going to get screwed up by water. Then you need to never take it out of a garage.
clh1220
st Louis
Thanks for the info. But I am smart enough to tell it's just water no brushes or cloths. I'm looking at your post and just thinking WTF. I said brushless.
loveracing1988
Clarkston, MI
Pretty much. The only ones I've ever seen advertised as touchless are essentially a fancy pressure washer.
ExpressRules
Southern New Jersey
Not doubting your intellectual prowess, just making the point that I have seen a number of "brushless" carwashes that use some form of material that wipes against the car. its all semantics as to an individuals thoughts on what brushless means. :favorites13:.
Andy578
Ontario, Canada
2014 Outdoorsman
that's why most are called touchless now and they are basically a pressure washer. some do have a brush they use on the rims tho so you have to watch for that but in most cases the rim brush is only used in the higher packages anyway
personally i prefer to wash it myself by hand but during winter it's not usually an option so i go through a touchless wash every month or so to get rid of all the salt
DanPop
2014 1500 Express
I can't believe the OP couldn't get an answer because you all had to **** on each other about car washes.
clh1220
st Louis
Go back and read he got a few answers. Told him to leave it running. Your not going to want to do the park bypass for the car wash.
Andy578
Ontario, Canada
2014 Outdoorsman
i never tried but can you not turn it off in neutral? there's also a neutral for the transfer case which is supposed to be used for towing so i'd assume it stays in neutral with the engine off
loveracing1988
Clarkston, MI
That is correct. For the sequence required to put the transfer case in neutral you would be out the other end before you got it shifted.
