My drivers side map light is out & the dealer says they can't just replace the bulb. Instead they have to replace the whole console. Does this make sense? Not to me. Has anyone ever replaced this bulb. If so how?
It depends if you have the OEM LED console then the bulbs are not replaceable as they are soldered on.
There needs to be class action law suits. There should be no light on any vehicle , that can not have just the light bulb changed.
A law suit? Realy? If the design uses a part that is not replaceable there is nothing to sue over. If this part was mislabeled as replaceable and folks were trying to do so and cause more damage and were responsible for the cost of repair, or personal injury happened due to the repair, than a lawsuit would ensue. However, it clearly states, and the operator was clearly informed they cannot be replaced. you can't sue a manufacturer over a design that is not convenient or cost effective for YOU. I'm no lawyer here, but I'm pretty sure no lawyer would pick up this case thinking they had a chance.
Additionally, the reason everything is going LED is because they are supposed to last forever and are more efficient, and generate less heat. These are not replaceable because they are not supposed to fail. I'm assuming these are defective and would be covered under warranty depending on your mileage. If your out of warranty then well crap happens and it was dumb luck they failed, and it's on you to pay the cost of repair.
It depends if you have the OEM LED console then the bulbs are not replaceable as they are soldered on and no replacement diode is available through Fiat. If you have the incandescent console then you can replace them.
For 2013 and 2014 the incandescent consoles were found on the lower trim trucks, say bighorn and down, and the LED consoles were on like the Sport and up models.
I am not sure but I think the incandescent ones may be being phased out as I saw a new exspress on the lot with the LED console.
RZrman328 If you have a 2012 you are correct you have the incandescent bulbs and these can be changed, judging by his screenname he has a 2014 sport which came with the LED console.
I'm not sure this warrants a lawsuit, but maybe this does? I've been checking the internet & it appears this is not a random issue, but instead it has cropped up in numerous vehicles & in same cases multiple times on the same vehicle. Chrysler knows about it & has done nothing to correct the problem thus far. And they will only do the repair for free if your truck is within the warranty period. Sounds like the makings of a class action law suit to me...A law suit? Realy? If the design uses a part that is not replaceable there is nothing to sue over. If this part was mislabeled as replaceable and folks were trying to do so and cause more damage and were responsible for the cost of repair, or personal injury happened due to the repair, than a lawsuit would ensue. However, it clearly states, and the operator was clearly informed they cannot be replaced. you can't sue a manufacturer over a design that is not convenient or cost effective for YOU. I'm no lawyer here, but I'm pretty sure no lawyer would pick up this case thinking they had a chance.
I dont know what to tell you, sueing is not justifiable here.. I have LED's in my tails and headlights, you think I like the fact that my headlights and tail lights cost 10 times more than the normal ones? It is what it is. If you don't like modern technology and some of the issues with it then don't buy a new truck.
Maybe one day these things will be replaceable, but honestly think about how much it would cost for a PCB with LED's and a connector through FCA, then you would still have to take apart the whole console to replace it - you would find that good enough reason to ***** about it. This is nothing new with LED technology in cars and its not total ********. This is the case in almost every car that has LED's, I find it hard to believe this is the first time you have heard of this since LED's have been widely used in cars for over a decade now.
Ya I've known about led. I don't think I have to agree with you. I still say it's ********* to make something that's a throw away like that. It could be made where it's not. Just think it's wrong to get screwed like that. If you don'tmind that's great. I could really give a **** less what kind of a light it is as long as i can change it. I don't have the dealer work on mine except for warranty. There is other post about this light and the puddle light on the mirror. But if you think it's awesome than it must be.
