Tow/Haul
smiley
Minot, ND
2014 Ram 2500 Crew
6.7L Cummins
Re
Gear
And
Win!
Seriously though I use tow/haul only when towing or hauling heavy. 4.56 gears make the system work well no tow/haul needed. I have the MDS tuned off.
jljbtm
jljbtm
I tried it again today and it does not go into the Eco Mode but it does show a 5 on the dashboard I do think the shift pattern is slightly different also
jljbtm
jljbtm
I don't think normal driving in this mode will save any fuel but over time it may save your transmission if you do a lot of towing or hauling
69GWC
Power Wagon
Spring hill, Kansas
2022 Power Wagon
6.4 Hemi, 8sp
my 8sp wont go into 8th gear with tow haul on, so no it wont save you on fuel.
LAram22
The 5 pops up on my dash when I use it also.
Who knows What that means?
Sent from my SAMSUNG-SM-N920A using Tapatalk
smiley
Minot, ND
2014 Ram 2500 Crew
6.7L Cummins
When you go into tow haul it shows the gear you are in just like it would if you manually selected a gear without tow haul. Since you have a 5 speed transmission I am guessing it will say that when in tow haul unless you select a lower gear. The trans will only use gears equal to that number and below when manually selected it is very helpful when defending long steep grades.
cubmedic
Danville, Va
With Tow/Haul on mine it will use all 8 gears. Just changes the shift points. Sounds better though. :favorites13:
UDCentaur
2015 Laramie
So anyone with an 8 speed using the tow/haul all the time ?
Quint
Minnesota
2021 Big Horn 1500
5.7L v8 eTorque
I will be tomorrow :happy107:
Quint
Minnesota
2021 Big Horn 1500
5.7L v8 eTorque
I have no clue how it may be affecting MPGs, but I definitely notice the higher shifting points.
