What to do with old tires?
BMRbrnSNRbrd
Norman, OK
2010 Dodge Ram 1500 CC Hemi Sport
I think I can come up with something. :D
[yt]L805tmESMjA[/yt]
2010 Dodge Ram Hemi burnout - YouTube
BTW, for anyone wondering..this is with 3.55s and an open differential. Also, these 4th gens have one hell of a traction control system. So, how did I just leave a nice set of tracks? You pull the ABS fuse and it removes all traction control. I seriously can't believe how well it worked. The nicest thing is you can plug the fuse back in and all is back to normal.
WhiteExpress
Midland, TX
Just saying... doesn't look like an open diff to me! I'll have to try pulling the ABS fuse. Turning off the Traction Control doesn't allow for any fun (atleast not on mine)
LB3711
Trumbull, CT
3.6L V6
thats not open diff for sure. You must have the 3.92 LSD option. I think sports can have that. I'll have to test mine I know I have 3.55 open.
Trac control is never off even when its off. Unless your in 4wd than you can disable it but press and hold till it says so in the EVIC.
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
thats sweet david!
quietpeen
2021 TRX
Hellcat
haha...that's awesome
BMRbrnSNRbrd
BMRbrnSNRbrd
Norman, OK
As almost everyone knows there is no LSD option with 3.55 gears on the new trucks. This is copied from my build sheet provided by Chrysler:
DMDS 3.55 Rear Axle Ratio
DRBS Corporate 9.25 LD Rear Axle
DS8S Conventional Differential Rear Axle
quietpeen
2021 TRX
Hellcat
that is weird that is spun both wheels with no lsd........my truck has the 3.55's also......when i was putting on my mufflex i looked at the sticker on the axle.
zack
pa
2004.5 packing the smarty
5.9 cummins ho
Sweet love to roll tires
ChloeBrooks
