Milt IV
- Aug 18, 2015
- 321
- 110
- TX M'F'er
- 2015 Sport
- 5.7 Hemi
About to buy some 24" SRT 10 wheels and I'm trying to figure out what tires I should get. I've used the online tire calculator so I know the dimensions, I'm just trying to see what everybody else is using. I will be doing the 2/4 drop very soon.
OPTION 1 - 305/35/24 is about 1/2" smaller than the stock tire overall diameter, obviously a lot wider than the stock, and side wall is in the middle of the three options.
OPTION 2 - 295/35/24 is almost a full inch smaller in overall diameter compared to stock, a decent amount wider that stock, and has the smallest sidewall of the three options.
OPTION 3 - 285/40/24 is the exact same overall diameter as stock, is a little wider than stock, and has the most sidewall of the three options.
option 3 seems to be the most practical, I'm just worried they might not be wide enough on the 10" wide wheel.
option 1 would look the best I think seeing as how they are so wide and have a decent amount of sidewall and are close to stock diameter. But they are also going to be the heaviest and most expensive.
option 2 seems like the worst choice because of the small overall diameter and the small sidewall. Of course this is the tire that comes on the wheels I want if I buy the "package deal" already mounted and balanced.
SO WHAT WOULD YOU GUYS DO?
