R/T_Fire
- Feb 3, 2015
- 3,432
- 1,205
- Pleasant Grove
- 2011
- Hemi 5.7
Does anyone know if or where I can order just 2" drop spindles? oh and remind me of how much farther they poke the tires out? Going to start collecting parts to update and fix some problem areas with the current lowering job on the truck this summer.
Also looking for pics of how a 2/4 wheel sits in the well and good up close pics of the spindle before the unit bearing was installed to see if I can machine that surface down if needed to get the wheel/tire to tuck and not hit the fender lip.
So my plan for this summer is remove the modified Belltech from my truck, install mcgaughys spindles with crown performance 1" drop springs up front with modified crown springs in the rear. I will also do Illicit's cut arm relocation kit, Watts link to do away with the Panhard I keep having to fight and readjust all the time cause something is moving back there and I cant find what yet.
Oh and I'll be going with QA1 shocks on all corners
