Stock R/T height is 285/45/22...
This may sound odd to do but its what I do when trying to find wheel tire conflicts on a vehicle, I will make a blank out of wood and cardboard.
Make a center blank, out of 1/4" or 3/8" plywood make sure it is all centered when you drill out the center bore and lug bolts. also make a wood spacer that you can screw that disc blank to that you actually bolt to the wheel studs. that spacer made from plywood stacked together or whatever is actually the depth of the wheel offset, then take a thin piece of flexible cardboard long enough to match the circumference of the tire. The center blank that is the same diameter of the wheel plus tire with the cardboard the with and circumference of the tire attached to it will let you know where the problems are...
If you want to get crazier you can take out your spring and shock to cycle the suspension also to find more conflicts if any
Hopefully that made sense, I type through it fast since I'm dicking off at work and need to get back to it
