Ak47bravo
The more I read through these forums, the more it bothers me...
It seems there really is not a good lowering solution for these trucks.... I mean, you either run one of two choices to drop: McGaughy 2/4 or Belltech 2/4. Then you need to get all the other associated parts to make the drop to actually make it ride at a bare minimum as good (with the goal of riding better) as the stock set up handles ... I.E.
QA1's
Sway bar end links front and rear
Panhard Bar
Upper and lower control arms
Upper adjustable ball joint
Then one may say, look.... you can not go to a vendor and buy a complete kit but you can go to several vendors and buy all the needed parts to have a "complete" kit so what is the big deal? We'll.. even of the listed parts, I still have not seen reliable data that the only 2 available adjustable upper ball joints and the few available sway bar end links to assist with ride quality when dropping our trucks are actually reliable... It seems every other week I am reading something saying that a part everyone thought worked well actually does not and has failed after a relatively short time.
Do y'all think a vendor will ever put some time and money into R&D to make a complete (reliable and well sorted) kit for these trucks to do a 2/4 or even a 3/5 drop (mostly just a 2/4 since the 3/5 is a bit more extreme and probably more difficult to keep the truck handling well without extensive modification). Or.... is there just not enough demand for a vendor to spend the time and money to do so?
I know I would be willing to spend the money to buy a well engineered kit. It is kind of frustrating that the 'Sport' edition of the ram has no changes to the suspension at all.... It doesn't seem that any car manufacturer actually makes a real sport truck, or even anything that somewhat resembles a real sport truck (i.e. decent susp. setup from factor, lowered, fairly quick, etc.)
I guess I come from a place of mind that I never had experienced this before. With my previous vehicles I lowered I put in performance coilovers and not only did they greatly improve handling but also lowered the vehicle a fair amount. Granted those were cars and did not have a foot of space between tire and fender to begin with (exaggeration) but still....
QA1's
Panhard Bar
