Hey guys, just purchased a 2014 ram 1500 5.7 hemi big horn crew cab and this is my very first truck. Taking a look at the forum, I must say I'm quite intimidated. The truck came with aftermarket cheap mastercraft 33" tires with the stock 20" wheel. It's also at least got a leveling kit (just a guess) but it's much higher than stock rams. And the precious owner must have done some sort of exhaust upgrade. So now she's mine and I could really use help from you all to figure out what's the best first upgrade to do. Wheels and tires? Cold air intake, headers, exhaust? Lift? I could really use some feedback so I can show her off on here
Nice truck. My advice is to put a fair number of miles on it before you change much with the running gear.
It looks like you have a set of Sport wheels which are a very nice wheel. If you want black, plastidip them to see what they look like. It can be peeled off if you don't like it.
You mentioned performance, which will not happen if you go to bigger tires that, in effect, will lower the effective rear end ratio number.
IAC, get a feel for the truck and drive it's wheels off. Then do what you like to make it yours.
Remember that HP increases significant enough to make a difference are not cheap. In the long term you might consider a tuner which should be a decent bang for the buck.
