2 inch front leveling kit
brandonjansen
Abbotsford, BC, Canada
2012 Ram 3500 Laramie Limited
Not all spacers. The Maxtrac system avoids this.
It helps reduce it, it doesn't avoid it. Any kit that still uses a spacer on top of the strut increases the total length of the strut and therefore allows the suspension to overextend. Their kit just reduces that amount of overextension as it's only a 1.5" strut spacer instead of a 2" or 2.5".
Spoon91
My 2016 2WD still has it's stock tires and it doesn't look "Too bad" with a 2" TGC leveling kit, Zone UCA's and Zone 1.5" body lift. I couldn't justify changing the tires yet seeing as they only have 6000 miles on them.
At some point I'll get bigger tire but for now I can deal with it.
Cmsharp
Rogers, AR
I did bilstein 5100 set at 2.1. Hankook atms stock size 33". It cost me about 400 total with shocks, install and front alignment. It still rides great.
Smxtmpr34
EcoDiesel
Yes just went through this hell. Got the coil spacers and it worked, but makes the front end feel like ****. Worked nice tho as it made room for my new wheels/tires. But wanted my front end to feel solid again so i went with the Fox 2.0's all around,, its a completely different truck now.. well worth the money
2017KRUSH
hey guys ..... I just got a new 2017 RAM crew cab ... at 65-75 if you change lanes it has body roll that's crazy .... I would like to level the front out or lower it not sure im torn .... if I level the front with a 2 inch .... whats the best way and should I change my shocks as .... what exactly are the 5100 you all keep mentioning here???? thanks in advance
freefallin
Is your truck 4x4? Congrats on your new truck!
Cmsharp
Rogers, AR
The bilstein 5100 shocks are adjustable for the front from 0.75-2.8 inches. Most set them at 2.1 to have about 1 inch of rake for towing. I love them.
Goodie1990
