Biggest tires with leveling kit
JFD3
Hellertown, PA
5.7L
Hi guys,
I’m sure this is posted somewhere on this forum but I can’t seem to find it. I have a 2014 ram 1500 crew cab. Currently running stock to 275/60 R 20. I installed a 2 inch lift/leveling kit and I’m curious how large I can go on tires. Obviously would like to avoid rubbing and I’m not averse to using spacers. I appreciate all your advice.
Adamcr68
Lorton VA
Hemifever 5.7
Hi guys,
This is mine with 35’s & a level, did have a slight rub on the uca at full lock. I had 18x9 +1offset fuels & ended up adding 1” spacers to fix.
I wanted to get rid of the spacers & like the more tire less rim look so replaced them with 17x9 -12 offset, no rub with this set up.
I do have a 1.5bl that wasn’t on in the leveled pic.
Dewbo
Hi guys,
I did a 3.5”......35’s would of been ok....the brand I wanted were 3 weeks out, I opted for 285’s and the catalog specs were 34.8”.....on stock rims, no issues at all.
OasisNinjaBat
