Gray2010Ram
The other day I tried to install my 2in leveling kit from fat bobs garage. I was wondering if anyone had any advice for removing the coil spring. I had the upper ball joint removed, the sway bar and brake caliper as well. when i lowered the lower control arm the spring still had tension and would not budge. I was looking at it and I was thinking maybe I have to remove the tie rod. Any help would be appreciated.
