Badger
- Oct 11, 2011
- 1,512
- 6
- Bettendorf, IA
- 2004
- 5.7 Hemi
Looks good
Im sure these will fit the 2012, i dont think they have changed the front suspension too much
yeah i just got done installing the spacers in the rear. I went with 1" tpg steel spacers. Im about to post a diy thread with pics and all. Just need to get to a level parkin spot to get a good all done photo. No i didnt change the rear shocks, and so far after about 5 miles the ride feels the same. yes i put bilstiens in the front and spacers in the rear because i set the bilsteins to max and it had the nose up look but i didnt want to take them back out to just tack them down a notch. so i installed the spacers in the rear myself which took all of about 45 mins.
Good write up on the back spacer install. How come you went with the steel one and not the polyurethane? Looks like now your rear is slightly higher now than the front. But if you tow, that is a good thing. I used the 3/4 inch polyuerethane cuz, I did not want any funky noises coming from back there using the steel one. I have mine set to max as well and I measure , both front and rear 40 1/8 inch from ground to wheel well.
the shocks cost me around 200 and the shop i had install them charged me around 180. than the alignment was around 140, thats a lifetime alignment deal at firestone.
