rt2878
Here is the problem, im running 37" nittos, my low tire indication is coming in for low pressure. the truck is equipped with a light load switch. and I currently have 58 pounds all the way around, what is the best pressure to run?
Edit for seeing your in a Cummins. They make tire pressure charts for a reason. Check nittos sight or give them a call. Still think 58 is high. I've had good luck chalking mine.
