Bilsteins on the way...
Fanta1500
Albany NY
Sorry just saw this now. Yes put on before the cap and I believe that was 30 lbs. there is a thread in here “guide to leveling” and it has all torque specs and literally everything you need to know about
Reactions: JB1
Quick_Shifter
IG: @ak_trucks_pa
TOTY Winner
ASTON,PA
AK Trucks Tuned 5.7
Can anyone tell me the torque spec for the sway bare end link nut?? Is it 75lbs?? That seems a little hefty to me
I know this is an old post but hopefully it helps someone one day if they're reading it.
Front Sway bar end link control arm side 75ft lb
Sway Bar side 20 ft lb (Tighten this while truck is on the ground "under load")
