Just join the forum, and I am reading Page 15 so far on this post. Lots of great information, I will finish up reading this post tonight, hopefully as I am a slow reader.
With that said, I would like to jump the gun on writing this reply as I have done tons of research on leveling my 2011 RAM 1500 Crew Big Horn. In addition to this reply I will disclose the cost of the material I have found on the net which might benefit to those in a tight pinch. So here we go. My final goal is to have a Zone 6" lift in the near future. But Spending $5000 (install, wheel and tires included) is not an option for me right now, I am archiving it in stages. I need to know whats that largest wheel and tire combo I can fit for my first stage which I dont have to replace my tire and rim down the road to achieve my goal.
1st Stage: Leveling and focus on parts I can reuse for my 6" lift kit. (Bilstein 5100 front $204/pr Ebay, Set at 2.1" MevoTech UCA $100/pr @ RockAuto. Tire Rod End Links $20/pr Ebay (My factory sets are loose time to change them). I am not touching the rear atm because nothing is reusable for my rear when I install my 6" kit.
So with $320 spend I have money for wheels and tire. I doubt a pair of 20X12 -44 Fuse Mavericks will work now, but I know they will work with the 6" lift, If thats true, I will settle with 20X10 -24 @ $1000, I just picked up a set of used Nitto Terra Grappler 295/60R20 for $140 (craigs list). Will this combo fit me for the leveling phase? if not I will reconsider rims with lesser offset. -19 maybe??
I think this is the cheapest (or best) way to go, I just want to make sure they can fit before I order my rims as they are the most expensive part for this leveling build.
Thanks in advance.
