Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 4th Gen : 2009 - Present > Lifted
Lifted
Kore / Adjustable Bilstein help
This is a discussion on Kore / Adjustable Bilstein help within the Lifted forums, part of the 4th Gen : 2009 - Present category!
So my buddy (a GM tech)and I installed a lift/level kit today. Consisted of: - kore high angle cvs - ...
Reply
Old 10-19-2013, 08:05 PM   #1 (permalink)
Ram Year: 2011
Engine: Hemi 5.7
Default Kore / Adjustable Bilstein help
Consisted of:
- Michigan metal works UCAs
- kore 3.5" adjustable bilsteins @ 3.5"
- icon vehicle dynamics 2.0 rear struts
- icon vehicle dynamics 1.5" rear coils
Dimensions before were; rear fender @ 39", front fender @ 36"
Dimensions after were; rear fender @ 40.5"' front fender @ 41.5"
Was hoping to have the front close to 39.5".
Everything went smoothly minus the usual 'stuck' items that required some additional 'help'.
I don't know why I got 5" of lift from these adjustable struts. We put them in the highest setting, which was only supposed to be 3.5".
Only thing I can think of would be that put the Bilstein spring seat on upside down, but it seemed to only fit the one way.
OR
We reused the stock spring seat, on top of the Bilstein one. Bilstein spring seat seemed to just be a part to connect the Bilstein retainer ring to the stock seat.
Any ides? Don't know what to try with that.
Thanks in advance.
Install is similar to how regular Bilstein 5100 adjustable shocks are, just with a higher setting, so looking for guys that have installed those to respond as well...please!!!
Sent from my iPad using Tapatalk HD
Sponsored Ad
Register to remove this ad.
__________________
2011 RAM 1500 WHITE CREW CAB SPORT
MODS: KORE PRERUNNER FRONT W/ MICHIGAN METAL WORKS UCAS / ICON 2.0 REAR / FUEL TROPHY 18x10 -12OFF / 295/70R18 TOYO AT II EXTREME / JJ RETROSHOP 5000K HID HEADS & FOGS / BILLET BUMPER GRILL INSERT / MAGNAFLOW CAT-BACK EXHAUST 16869 & Y PIPE 10778 / RECON SMOKED LED TAILLIGHTS & 3RD BRAKE LIGHT / BLACKED OUT EMBLEMS / LED INTERIOR & EXTERIOR LIGHTS / BILLET CATCH CAN / S&B COLD AIR INTAKE / MOE'S 87MM THROTTLE BODY / CANINE COVERS REAR SEAT PROTECTOR
StevoTee is offline   Reply With Quote
Old 10-19-2013, 08:18 PM   #2 (permalink)
Ram Year: 2011
Engine: Hemi 5.7
Default
Should've mentioned its a 2011 1500 sport.
__________________
Old 10-19-2013, 09:32 PM   #3 (permalink)
greychevy's Avatar
Ram Year: 2012
Engine: Hemi
Default
Any pictures?
__________________
Ethan
First & only 4th gen 4x4 in the 12's NA 12.747 @ 104.07 (1.663 60')
2012 Black SC 4x4 1500 Hemi ARH longtubes, Vararam intake, Circle-D 3000,
Moe's 87mm throttle body, efan, 2010 frontend swap/4.56 gears, Greene Racing tune
greychevy is offline   Reply With Quote
Old 10-20-2013, 12:58 AM   #4 (permalink)
Thor09's Avatar
Ram Year: 2015
Engine: 5.7L Hemi
Default
Yes pictures will help figure it out. Did you get an alignment yet? The front will drop some after an alignment but its pretty crazy you're 5" higher when its suppose to be 3.5" or less
__________________
2015 Ram Sport Crew - Ceramic Blue
Vararam, 18" Mufflex, Moe's 5" tips, Mevotech UCAs, Bilstein 5100s maxed, 1" TGC rear spacers, Goodyear Duratrac 305/55r20, 20x10 -12 Fuel Couplers, 42" curved lightbar, some HIDs and LEDs...
Thor09 is offline   Reply With Quote
Old 10-20-2013, 12:55 PM   #5 (permalink)
Ram Year: 2011
Engine: Hemi 5.7
Default
This is the "spacer" which slides over the body of the strut and butts up against the snap ring.
No alignment yet, didn't see a point since its off by so much.
__________________
Old 10-20-2013, 01:38 PM   #6 (permalink)
CaliDodgeRam's Avatar
Ram Year: 2012
Engine: Hemi 5.7
Default
Pictures of the lift on the truck?
CaliDodgeRam is offline   Reply With Quote
Old 10-20-2013, 05:12 PM   #7 (permalink)
Ram Year: 2011
Engine: Hemi 5.7
Default
No pics yet, and I don't have the truck, it's at the shop still.
When you use the 5100 adjustable shocks, are you supposed to put the stock strut mount (slides over the strut) directly on the snap ring?
__________________
Old 10-20-2013, 05:49 PM   #8 (permalink)
mattman_13's Avatar
Ram Year: 2012
Engine: hemi 5.7
Default
That pic you posted. That piece should be placed over the strut with the fatter end down and it so it slides over the snap ring. I think its slightly tapered so the weight of it helps secure the snap ring in the groove as well.Only reason iI point that out because you seemed questionable and said it "butts" up against it" as opposed to slides over. That would definitely add the questionable height you have!
__________________
TEAM BULLY'S PERFORMANCE
mattman_13 is offline   Reply With Quote
Old 10-21-2013, 03:53 PM   #9 (permalink)
Ram Year: 2011
Engine: Hemi 5.7
Default
Yah, I found some more detailed instructions (didn't have any when we did it), and now I'm pretty sure that's where we messed up. Think all we have to do is flip it.
I just hope that it didn't mess up the strut/ring or both.... keeping my fingers crossed.
__________________
Old 10-21-2013, 08:11 PM   #10 (permalink)
Ram Year: 2011
Engine: Hemi 5.7
Default
So, we had one installed right side up and the other upside down... Switched the one which was upside down and reinstalled.
Measured the strut assembly and was still the same length (5" of lift). Lowered the ring to stock setting and was still getting 2.5" of lift.... Wtf?
So, I'm at a loss. Going to bump it 2 settings up so it's close to level....
Any ideas?
Sent from my iPhone using Tapatalk - now Free
__________________
Reply
Tags
bilstein install help, bilstein parts list
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Looking for Bilstein Adjustable 5100 deals Bluesmoke91 Lifted 3 10-22-2013 10:28 PM
Bilstein 5100 height adjustable OGsohcHondaLOVE Lifted 2 03-15-2013 09:10 PM
Bilstein Adjustable 5100 and 35's ctechnow Lifted 1 09-18-2012 04:28 PM
Bilstein Adjustable Shocks TXKID Lifted 1 05-14-2012 09:24 AM
where to buy bilstein adjustable shocks? AJMAG General Discussions 10 04-15-2012 11:12 PM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
