lift kit help
Musclemckeester
Houston, TX
n/a
n/a
The Kore stuff is good stuff just usually priced fairly high, but that doesn't seem bad at all. Did you notice it says at the bottom you'll need aftermarket wheels 17x8 with 4.5" of backspacing?
nyflightmedic
Hemingway 5.7
2012 RAM with leveling kit...
I am installing a 6 inch rcx lift this weekend.
Do I need to remove the leveling kit?
sbuko213
Hendertucky, NV
6.7 HO
helloo again guys I found this lift kit it looks great , with a high price tag but I think its the only way to go tell me what you guys think :)
KORE Prerunner Series for 2009-Current Ram 1500
That's about the same price wise as you would be getting with a 4" drop bracket kit. If you're looking at doing a 3 inch suspension lift (with coilovers and such) be prepared to drop big money because they are generally higher performance mid to long travel kits. Also Kore does not really make anything anymore. Look into Icon, they make a very similar kit with coilovers.
xrsman
Ontario
3.0 Ecodiesel
Lmao I don't think he need the advice anymore! Look at the date of his post ;)
xrsman
Ontario
3.0 Ecodiesel
If you have the rancho quick lift or bilstein struts than no. If you have a spacer level than yes you do
maxx offroad
2013 dodge ram 1500 sport
just lifted a truck with a 3.5" level kit
hey guys
I have recently installed a 3.5" level kit ( ebay special) on a 2013 dodge ram 1500 was not easy to install...... had to put extended brake lines we got it up and running with a set of 35' m/t's but there is some seroius pot hole wobble is this kit safe???
Rzrman328
The treeline
hey guys
Probably not.
Robert Bednar
Montana
Dodge Ram 2018
3.6 L V6
Great looking truck. Yeah, there are better lift kits out there that are a little bit bigger. I recommend the Tuff Country if you are looking for something a little bit bigger than the 2 inches. For newer Dodge Rams, they have up to 4" of lift available. For older Rams, you can get up to 4.5" of lift.
