- Jun 14, 2017
- 121
- 99
- 2016
- Hemi 5.7
I am about to level my truck with bilstein 5100's and a TGC 1" spacer in the rear. I figured while I was at it I would replace the UCA's with mevo's as well. My plan is to do it Friday morning (may do the rear after work on Thursday) so I can get my tires mounted on the stock wheels and get the alignment at the same time.
In the past when separating the ball joint from the knuckle I have hit the knuckle with a hammer to separate it but I have heard on these 4th gens that it could damage the knuckle. I have a pickle fork but I don't want to damage the boot on the stock ball joint. How are you guys separating them?
What point should I torque the UCA and ball joint? I am assuming it needs to be snugged up, put the wheel back on and torque to spec once it's on the ground under load, is that correct?
I have no concerns with the install, just want to be sure I am get the torque right and the way it should be done without damaging the new parts.
