24 inch wheel offset question
brobinson1283
Hey guys. I am finally looking to put rims on my truck and thendoing the 2-4 drop on it. I have been looking all over the internet and ebay for wheels. I finally think i found some I want. Here are the specs:
Rim Width: 9.5
Offset: 15
Bolt Pattern: 5x115, 5x139.7
Am I going to have any issues with fitment on these. Everything seems to be right. Just not sure on the offset. I dont want these sticking out past the fender at all. In case I decide to bag it at some point. I am planning to put 305/40/22 tires on them. Any help thanks.
Here is a link to them: 24x9.5 Machined Black Cratus CR008 Wheels 5x115 5x5.5 +15 Fits CHRYSLER 300C RWD | eBay
Eestee70
Chicago
It shouldn't be a problem with rim width, but you may have a problem with offset. I think of oem offset is between 0 and -15 depending on the wheel. If you can....find a custom wheel shop in your area and see if they will test fit a wheel with that offset that way you will know for sure. Good luck
bgray
Canada
no problem. You might see SLIGHT rubbing on full lock turning, but thats nothing to be concerned about
I run 24x10 +25. I run 305/35r22
Mpgrimm2
SC
2022 Ram 1500 (5th Gen)
5.7L
How do you run a 22" tire on a 24" rim?
Typo?
M² Mods - From my non Flammable S7!
DRkNESS
South Jersey
Oh I thought he meant that he runs a 22" wheel, my bad.
brobinson1283
brobinson1283
Yes typo. 24 inch tire. on 24 " rim. So the +15 offset should be okay. Every rim I have been looking at seems to have that offset on it. I have only found one other with a +18
FluidConcepts
Oklahoma city
I have 24s with that offset and they will not tuck. They are flush with the body and don't stick out. My bagged ram has.custom wheels with an offset to tuck
bgray
Canada
it'll work. Unless you have drop spindles then your in a different boat.
ohh7_5sevum
War size tire are you runnin
Kab
I actually just purchased them 24" cratus wheels with the +15 offset, I'm using 295/40 tires and I know there'll be no running. The stocks on my 16' are 20x8 with a +19 offset.
BlownGP
Houston/Baton Rouge
Yeah, you will be fine with that offset.
Lownismo
Curious! How did your 24’s fit and what tire size did you with?
