Bfgoodrich all terrain vs general grabbers at2
arsenault408
When summer comes I'll be needing new tires but I'm not sure on what to get I'm looking at bf Goodrich all terrain ko2 and general grabber at2 I need something that'll perform good in snow as I live in Canada. And should I go with 20's or 17's here are some prices
20's
All terrain ko2 35x12.50x20
392,77 a tire
General grabber at2 35x12.50x20 362,74 a tire
toyo open country c/t 35x12.50x20
387,10 a tire
17's in the same order
340,61 a tire
287,61 a tire
332,67 a tire
Another question is would a 35x12.50 fit with just a 0mm offset rim with a 2in levelling kit on a 2010 Dodge Ram 1500 or should I be looking for 35x11.50 or 295/65/20
My truck sits on 35/12.5 and I only have a 2 inch level and a 0 offset rim. I don't have a rubbing issue so you should be fine. As far as tires, I've run both tires in a previous truck and I definitely liked the KO2 better than the general.
A
arsenault408
Thanks for the information on the tire size I was a little puzzled will they fit or will they rub some says you need at least 2.5 to clear 35x12.50
coldfusion73
Ontario, Canada
You should also seriously consider the Goodyear Duratracs! But I do like the looks of the General Grabbers over the BFG's.
This is what my truck looks like with the 35s
A
arsenault408
Are you sure the duratracs comes in 35's ?
jared181920
Ontario, Canada
They do indeed! The 315/70/R17 Duratracs measure out to around 34", close-ish to 35".
I just bought a set before Christmas for my 1500 and they have done quite well in the snow so far.
Only downside to that size in the Duratrac's is they aren't E-rated, but that's not a huge deal for most I don't think. I do notice a difference when compared to my E-rated Trail Grapplers, but for day to day driving it hasn't mattered.
A
arsenault408
Going that route I'd have to get 17's cause a 315/70/20 are like a 37
