Fog Lights on with High Beams
tobyjohnson11
I have been trying to figure this out for a while.
My buddy has a 2010 2500 ******* with an H&S Black Maxx Tune on it. Within the tuner her can turn on a option to allow his fogs lights to work with the high beams. On the H&S website it says
"Fog Lights W/High: Enable / Disable the fog lights staying on when high beams are being used."
I called H&S and of course they don’t have anything that can make a hemi do this. But since they figured out a way to make it work, I know it can be done. Anyone have any other suggestions on a company that could get into the ECU and turn this feature on for us?
swamp_life hemi 05
Tallahassee Fl.
2005 laramie
For 06 and newer on the bully dog like I have there is that option. I wish it had it on my model.
Droid Incredible 2 on the move!!!
quietpeen
2021 TRX
Hellcat
Right now there is no way that i know of unless it can be done at the dealer and you can talk them into doing it. There are no turners for the 2011 and 2012 Hemi's, i guess they can't get past the encryption.
Stangshcky12
Oshkosh, WI
5.9 Cummins
I enabled this option on my girlfriends dads 09 CTD with his minimaxx and it makes a huge difference
I'd like to be able to do it to her 05 as well
quietpeen
2021 TRX
Hellcat
it can be done on the 05 by using a jumper wire in the the fuse box, but i sure as hell don't remember which fuses or which prong on the fuse you have to use....LOL
trev
I found a kit on eBay a couple of days ago that worked for the 4th gens you might look on there.
swamp_life hemi 05
Tallahassee Fl.
2005 laramie
Search for jumper mod. For the 05, I did it using that thread
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
LINK! quit teasing us.
Madcow has his set up for it too......just not sure if it was done with a relay, or what.
LB3711
Trumbull, CT
3.6L V6
Sweet. When are these idiots going to get a tuner for us 2011's?
Sent from my tapatalk equipped AT&T iPhone 4.
trev
I'm sorry! I don't remember what it was under to find it again!
garner
Harker Heights, TX
There's a way you can get it to do it for about 20 minutes on the 2011s. You hold the high beam stalk towards you and it keeps the fogs and highbeams on at the same time
T
tobyjohnson11
Who wants to drive down the road holding the stalk. HAHA:Grenade:
Thats what mods area for.
smiley
Minot, ND
2014 Ram 2500 Crew
6.7L Cummins
Why do they limit this anyway? I rarely use high beams because I can't use my fogs too. Seems like an easy thing to make how the consumers want.
$miley
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
I went to buy one........what the hell........but eBay says local pickup only.
Their website shows $14.50 for shipping. Screw that.
phorrestphire
