Sir John
- May 28, 2014
- 1,830
- 896
- Buffalo, NY
- 2016 1500 Rebel "Mopar 16" Special Edition
- Hemi 5.7
I know that some of you definitely know this answer. How should the HID bulb return wire be pointed in oem projectors?.....up or down? I remember the oem projector’s bulb holder is not intended for HID bulbs and their return wire, so as a result you can end up with a shadow when your low beams are on from the return wire. I rather not have that if I can help it. Also, has anyone managed to correct it somehow?.....for example, clipping the HID bulb tabs to allow you to put the HID bulb’s return wire in at a different location? I appreciate the help/advice!
