I just rotated mine with 8000 miles on them. My feelings are the same as echoed above except mine will probably last 40k miles if I had to guess. They hum a little but that was partially my fault as I went longer than I should have before rotating and the front ones were cupped some since I have a lifted IFS truck. Would I buy again? Probably.
One thing to add: The rears were wearing a bit faster than the fronts. That is of no fault of the tires but more fault that my truck has 395 HP and I take off aggressively from time to time. [emoji23]
I take off aggressively all the damn time... my rear ko2s look like ****...
Sent from the fetal position using Tapatalk
Has anyone had them in snow, ice and mud yet? How about tire pressures and contact?
Damn that sucks. Maybe you got lucky and it's just a shorty screw? Happened to me once, not with these tires though. I took it to the local Discount Tire to have them pull the screw and patch the tire and it was a little quarter inch long machine screw with a big ol' pan head; it didn't even fully penetrate the tire. Maybe used in HVAC? Idk but I felt dumb lol. Now I'll just pull them myself and let the tire go flat if it's going to lol.
How many miles do you have on the tires? They still look pretty good.
I passed 6k at the end of December and forgot to do an update and forgot to have the tire shop throw a depth gauge on. I haven't driven much in January so probably around March or so I'll have 9k on mine and have them rotated and a tread depth check. I will say they're getting louder as they wear a little but wear is even so far. But I rotate every 3k miles so I expect that. So far a good tire for the money though.
