Thanks for all that info! I have the projector style headlights do you know if those would work for me?
I'm willing to get both for the fog lights and also the projectors its just that I was told by someone that LED's won't fit in the projector because of the fan and can't put the back cover on. If it's possible I'd get LED in both preferably just don't know the bulb sizes for each
I know the MostPlus 9005's I linked above will 100% work and fit in the fog lights of a 4th gen Ram but I'm not sure about the headlights.
However I do know for a fact that the Opt-7 FluxBeam-X LED's WILL fit into the projector low beam spot. A few members on here have fit them inside aswell as a ton of members over on the Ram Rebel forums.
Here is a link to the Opt7 FluxBeam-X LED's:
http://www.opt-7.com/fluxbeam-x-led-headlights/
They will definetly fit the oem projectors and they come with the ecm capacitors to prevent flickering and bulb out warnings. So they include everything you need to get then working.
It will be a tight fit to get them in there with the dust cap back on but they WILL fit. Don't worry about the fans being in there, they get plenty of air and the led's run super cool anyways. I know a few people who have the led's with fans in their fog lights for over a year now and through all the rain salt and snow they have had no issues with the fans breaking or stopping.
So the MostPlus 9005 are the best bang for your buck for your fog lights and the Opt7 FluxBeam-X 9006 (will fit the same as a 9012 bulb) are your best bet for your low beam in the oem projectors.
Sent from my SGH-M919 using Tapatalk
