I have everything it, but will have to wait until Saturday to do the install. By the time I get home from work it is dark (Oh the joys of winter).
So far, I have done the following: (Thanks for all the PM help Demon-HeMi)
Received RetroShop H7 6000k 35 HIDs
Received RetroShop Quad to Projector Adapter Harness
Received DT Moto prjector housings
First, I drilled 7/8" holes in the back of the light housing adapters using a step drill bit (Harbor freight). I then used grey RTV to make a true weather seal around the wiring. You will note that these HID bulbs are separate from the wiring (The cover on the right, the two wire connector attaches to the back of the HID bulb the other two male connectors attach to the low beam connector):
Here are the light housings waiting to be installed. I already installed the HID bulbs, put dielectric grease for ease of future connector removal, and put the covers back on. Here they sit with the manufacturers scratch protecting covers:
Next step on Saturday is to remove the factory Quads, install the HID Can bus wiring harness, then install these.
