Wheel/Tire Guru's...question if I might?
BigDogg795
Ronkonkoma, NY
Started BigDogg's wheel and tire fund this week and plan on having enough to pick up a new set of shoes by the time it warms up again in NY...I think I'm going to downsize to 17's but keep the 33" rubber...looking at a 285/70/17. My question is; I really like the Blackrock Yuma's and want to make sure all is alright with the back spacing and what not. I'm not 100% on the difference between the offset and backspacing relationship but from what I've come to understand 4.5 BS with a 0 offset should work as long as I don't get too crazy.
I'm stock suspension, no level, nothing and I don't think I want to go to a larger tire either (I'm doing highway miles, there's really no place to go mudding in Suffolk County to my knowledge lol).
So, will I be safe with a 4.5 BS, 0 offset with a 285/70/17? Thanks in advance boys and girls, I appreciate the advice!
DannyMK2
Long Island, NY
2015 Power Wagon
youll be fine with that set up. i would go with a 9" wide wheel if it were me though.
Jerry1984
Meridian, Idaho
You'll be fine for sure. I have 33x12.5 on 17x9 -13 which stick out a little more than your proposed setup and have zero rub.
To the above its hard to tell from the highlighted info but I'm guessing they are 9 inches wide if they have 4.5bs with 0 offset. 4.5 is half of nine and 0 offset means it's in the center.
BigDogg795
BigDogg795
Ronkonkoma, NY
Yeah, the attachment isn't as legible as I'd hoped. But according to black rock the wheel is 17x8...not 9. Basically I like the utilitarian look of the wheels but don't want to get steel because of the weight concerns.
Sent from my Startac using 1XRTT.
AustinB
Banned
San Diego, Left Coast
Just throwing this out there.. A 9" wide wheel with 0mm offset is 5" backspacing. 8" wide would be 4.5"
Edit: I would avoid 8" wide rims if possible... A lot of the really nice tires, especially in the 12.50 wide range will not fit an 8" wide rim.
BigDogg795
BigDogg795
Ronkonkoma, NY
Should be 9 in wide wheel.
If these were 9" I'd have it settled; but according to all sources the Yuma is a 8" wide wheel. Granted I'm not looking to do a 12.50 tired (again, mostly highway miles on my truck)...but long term should my plans change I wouldn't want to have to change out the wheels to something I potentially wouldn't like.
DannyMK2
Long Island, NY
2015 Power Wagon
17x8 and 285/70/17 are the stock sizes for the rebel and power wagon. nothing wrong with the combination, its merely preference. the 8" wide wheel almost has a balloon look to it. its not as noticeable on the 17's though. i wish my power wagon came with 9" wide wheels, but it doesnt look bad as it is. the face of the rim is going to stick out a hair more then the OEM chrome clads and youll have a little more tire poke.
AustinB
Banned
Why in the ffffk is ram putting 8" wide wheels on their trucks? Especially trucks "designed" for off road.
IMO
BigDogg795
BigDogg795
Ronkonkoma, NY
The Rebel is actually where I got the specs from but I didn't know what the back spacing was.
BigDogg795
BigDogg795
Ronkonkoma, NY
IMO
Wish I knew bro lol...either way, when I get the money together at least I know it'll fit!
