Trapinator
Decided to wrap the plastic trim around the 5th window on the back glass. It's not recommended because it is plastic, as well as orange peel texture. I live in Houston where plastic fades fast and the back window bugged me with it fading, so gave It a try since I had some. It actually stuck good (cleaned surface, and used heat gun) when the glare hits it you can see the texture but I'm happy with it. Blends in with the glass much better!
