All the instructions that I've read so far say to pop off the lens cover and pull the bulb out. The 2013's have the chrome plate in there and another plastic housing that has the bulb behind it. Do I need to remove the entire overhead assembly to get behind the chrome plate and housing to get to the bulb? (note: I already got it halfway off and still couldn't access the bulb) I don't wanna pop stuff off and risk breaking it if I don't have to.
And I tried the back dome light tonight, same issue. The bulb is encased within another lense which also has a chrome plastic piece completely filling up the area behind the lense cover. It isn't obvious how to get to the bulb. Any insight out there? Thank you!!
